Replacement Headlight Bulbs for 95 LS400
Old 07-05-06, 09:26 AM
udontknow
udontknow's Avatar
Default Replacement Headlight Bulbs for 95 LS400
I want to get thet HID look but without getting the conversion kit. This website http://www.carxpressions.com/lightin...ight_bulbs.htm has a bunch of them and they tell me what fits in my car. But I wanted to know if anyone can clarify what the different types are ans are some for high beams and some for low beams.
Thanks
Old 07-05-06, 02:19 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
do a search, theres tons of answers to headlight questions for the UCF20.
Old 07-05-06, 04:58 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
The link you provided are not for HID lights. They are nothign more then painted holagen lights.
Old 07-05-06, 05:10 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
Moe, that's why he said "I want to get thet HID look but without getting the conversion kit."
Low beams use 9003 or H4 and high beams use 9005.
Old 07-05-06, 05:17 PM
PureDrifter
BahHumBug
The fogs are 9006 bulbs FYI
Old 07-05-06, 07:01 PM
udontknow
udontknow's Avatar
Thank you sooooo much. You guys are so helpful.
Old 07-05-06, 07:27 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
oops, sorry about that. Thanks for the heads up Brian. Im just so used to those threads, I guess I was not paying attention.
Old 07-06-06, 10:00 AM
ychachad
ychachad's Avatar
Yeah and you can easily perform a foglamp conversion from 9006 to the 9005 bulb for almost twice the light. I have mine in there for over 23k miles or 1year and 8 months without the shorter life 9005 burning out.
Old 07-06-06, 10:13 AM
Alan D
Alan D's Avatar
So you can run the 9005 in place of the 9006 without any wiring changes correct? If I remember correctly these are the same bulb except one is intended to be used as a high beam and the other as a standard.
Old 07-06-06, 08:35 PM
CUMan
CUMan's Avatar
The 9005 bulb and the 9006 bulb use the same wiring; however, they have slightly different tab structures where they fit into the bulbholder. You can modify a 9005 to fit a 9006 holder by removing a small part of the center plastic tab. It is somewhat difficult to describe what you have to do; however, if you compare the two bulbs side by side, you will quickly see how the 9005 has to be modified.
The wattage of the 9005 is slightly higher, and it does not have the blackened front end. Its light output is higher than the 9006.
Old 07-07-06, 04:26 AM
ychachad
ychachad's Avatar
Yes there is no wiring change. buy a 9005 bulb, put them side by side, get a dremel and you'll know what to do.
Old 07-07-06, 06:08 AM
Alan D
Alan D's Avatar
I have some extra bulbs in the garage from my last car that I can modify and try out. Will give it a shot this weekend. thanks for the info.
Old 07-07-06, 01:34 PM
PureDrifter
BahHumBug
heres a link t o a diy tutorial for the 9005-9006 conversion.
http://www.bmwe34.net/E34main/Upgrade/More_light.htm
Old 07-07-06, 02:22 PM
Alan D
Alan D's Avatar
Excellent! Thanks for the info. I'll do the change this weekend.
Old 07-07-06, 11:02 PM
Stu
Stu's Avatar
Oh I have one this, and trust me its not worth the effort.
Buy some HIR bulbs. They use new technology and they really are amazing.
Quick Reply: Replacement Headlight Bulbs for 95 LS400
