Installing an after market radio in a 1995 LS 400
Old 03-25-08, 06:39 AM
  #31
4onesam
4onesam's Avatar
Default Aftermarket Radio Help!!!!
Originally Posted by Lexkost
I CAN'T FIND THAT WEB SITE CAN YOU PLEASE HELP I AM TRYING TO PUT A
AFTERMARKET RADIO IN LIKE YESTERDAY.
Old 03-25-08, 06:47 AM
  #32
Neofate
Neofate's Avatar
Cureline.net is offline atm . They should have it back up soon.
Old 03-25-08, 06:49 AM
  #33
Neofate
Neofate's Avatar
Try this PDF, see if it helps:
www.lextreme.com/Lexradio.pdf
Old 03-25-08, 11:47 AM
  #34
Patrickb
Patrickb's Avatar
i got a question if you wanted just a little more punch ( i have the non nak stereo) can you put a better 8" sub in the rear deck and mount amp for it. if its already been done how did it sound.
Old 03-25-08, 12:51 PM
  #35
Neofate
Neofate's Avatar
Its been done many times -- Provided you get a decent Freeair (IB) sub, they sound fairly good. Much better than factory. Some people cut out the hole a little and put a 10 in there instead.
If you search, you will find alot on this topic.
Old 03-25-08, 12:57 PM
  #36
Patrickb
Patrickb's Avatar
yeah figured as much. thanks for the help
Old 03-25-08, 01:45 PM
  #37
PureDrifter
BahHumBug
PureDrifter's Avatar
actually retro's site has been down a few months now so i wouldnt expect too much
Old 07-30-08, 11:50 PM
  #38
ryguypv
ryguypv's Avatar
Sorry to post on an old thread, but...
Any ideas on how to find the appropriate inputs for a nakamichi amp? I am installing an aftermarket headunit, and I want to take the pre-outs and wire them to the existing amp inputs. I'm kind of resolved to using a multimeter and panning and fading to find which speaker I'm testing. Any other ideas?
Old 07-31-08, 09:19 AM
  #39
PK_Celsior
PK_Celsior's Avatar
here you go. this is what i did with my LS400. since i wanted to use my stock amp w/ an aftermarket deck. but dont forget your sub wont work anymore.
http://www.circuitcity.com/ssm/Metra...oductDetail.do
i bought that. i cut off all the RCA plugs, because the harness is useless.
http://xplayazplayzonx.multiply.com/...e_Diagrams%231
http://xplayazplayzonx.multiply.com/...e_Diagrams%232
theres a link to the wire diagram. so i use the RCA Plugs and tapped it into the original amp wiring. so it gives you RCA for the preouts. hopefully this is what your getting at and this helps you out
Old 12-11-08, 06:12 PM
  #40
cnewman402
cnewman402's Avatar
See this thread it is my data journal for install 96 LS400 stereo.
https://www.clublexus.com/forums/ls4...-diagrams.html
Polvoron
10-18-18 10:43 AM
jimmycofc
08-06-16 01:37 PM
jmannewitz
12-08-06 01:03 PM
SSmith
12
08-25-03 05:13 PM
Quick Reply: Installing an after market radio in a 1995 LS 400
