1992 LS 400 sunroof
Old 06-08-06, 09:45 PM
Gary B
Gary B's Avatar
Default 1992 LS 400 sunroof
There is a leak, apparently on the front of the seal of the sunroof that needs repair. It is my understanding that the seal is part of the sunroof and that replacing the seal involves replacing the sunroof. Is that correct, or is there a simpler (read - cheaper) alternative? Is this a job I can do myself, or am I headed to the dealer for a session with my checkbook?
Old 06-09-06, 04:14 AM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
Default Welcome to the forum
Try reading this thread first and see if it helps.
More threads I found by doing an advanced search on 'sunroof leak' in the LS400 forum...
https://www.clublexus.com/forums/sea...earchid=667350
Old 06-09-06, 08:44 PM
CUMan
CUMan's Avatar
More than likely, the problem does not involve the seal around the sunroof. Instead, one or both of the small drains at the corners of the sunroof are probably blocked with dirt and other debris.
You have to get these drains opened up.
This problem was discussed on the LS 400 forum in late May. Do a search on "sunroof leak."
Old 06-12-06, 09:09 PM
AussiLS400
AussiLS400's Avatar
There are 4 drain pipes. 2 in the front pillers and 2 in the back. Have to take the head lining out to get to all of them.
Old 06-12-06, 09:48 PM
CUMan
CUMan's Avatar
Yes, there are four drains. I inferred from the description of where the leak was occurring that the front drain holes were involved.
If the rear drains were blocked, I think the leak would be in the rear seat area or in the trunk.
Old 06-17-06, 07:55 AM
LS400_93
LS400_93's Avatar
Default Sunroof leak
Hi all, I can't find the threads on the sunroof leak but I do spray mine out about once every 6-8 months. I went to a hardware store and fashioned a nozzle with an on/off valve and a tip that fits into the drain holes on the sunroof channel (total cost = $11). I just hook up the hose to this nozzle, and spray them out.
Mike
RosieBoy
ES - 5th Gen (2007-2012)
11-08-17 01:37 PM
305ls400
03-17-11 08:28 PM
sjnmsn
07-17-06 06:12 PM
Bradster
06-16-06 06:50 AM
The Ikon
Maintenance
04-30-01 10:09 AM
Quick Reply: 1992 LS 400 sunroof
