Fixing Door Panels
Old 05-26-06, 05:10 PM
Suneet
Suneet's Avatar
Default Fixing Door Panels
I'm not sure if any else of you have run into this problem, but I sure have. Having removed both my front door panels numerous times to get my new components in, I've destroyed some of the clips on them. On my drivers side 3 of the clips are stuck in the door and are slightly broken, and on the passenger side one clip is missing . The lack of clips allows a lot of road noise to enter the cabin and doesn't give the panel a tight fit. When you open the door and look at it you can see a slight gap.
Is there anywhere you can get extra clips? What have you guys use/done to circumvent this problem? I think with the clips that broke I'll try using a small piece of wood on the back side and glueing the clip to the door panel. But I'm sure that will break just as easily the next time I take out the panel.
Share some of your suggestions..
- Suneet
Old 05-26-06, 06:02 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
call ur local lexus dealer, they aught to be selling them cheapish.
Old 05-27-06, 10:01 AM
Lexkost
Lexkost's Avatar
Pep Boys has clips that will work.
Old 05-29-06, 11:31 AM
Suneet
Suneet's Avatar
Thanks, I should of just called the Lexus dealer first. They have them for $3.60 a clip. I'm going to try pep boys, becuase for 12 clips, thats a good $40!
Old 05-30-06, 12:08 PM
denverdog
denverdog's Avatar
contact a local glass shop. they must go through clips faster than anyone. i'll bet they have clips, or can tell you where to get them cheap.
Old 05-30-06, 05:19 PM
RA40
Super Moderator
RA40's Avatar
Stop by a Toyota dealership with clip in hand and see what price they quote. Last time I was by to get clips for another Toyota, they were $1.20 each. I dunno what the clips look like in the Lex but so far, it's pretty much been the same style.
clickart
RX - 3rd Gen (2010-2015)
12
05-05-14 08:44 AM
radio9
06-19-10 02:19 PM
1sxyrxy
SC- 1st Gen (1992-2000)
02-09-06 05:34 PM
007lexus
04-24-02 10:13 AM
Quick Reply: Fixing Door Panels
