VSC Warning
Old 05-17-06, 03:08 PM
teddy4050
teddy4050's Avatar
Default VSC Warning
98 LS400 I've had the warning light, Check VSC message and engine warning light come on several times and fail to reset itself. First couple of times was it happened when I let low fuel light come on (it wasn't that low) each time I had to get a dealer to reset it and yesterday it happened again but the fuel wasn't low (although I did spin on some gravel). Can I reset it myself (the owners manual says it will reset itself but it doesn't) or do I have to take it in each time this happens? Also, I lose power and the gas pedel doesn't seem to work right unless I floor it, then the car lurches forward, not good. What's going on?
Last edited by teddy4050; 05-17-06 at 03:14 PM. Reason: I forgot about the power loss
Old 05-17-06, 04:10 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
To reset, pull the main ECU fuse for a few minutes. Or unplug the negitive terminal to the battery for 15 mins.
Old 05-18-06, 02:16 PM
RODDMOD
RODDMOD's Avatar
98 LS400 I've had the warning light, Check VSC message and engine warning light come on several times and fail to reset itself. First couple of times was it happened when I let low fuel light come on (it wasn't that low)"
Your Battery is on is way out or your Battery connections need cleaning."
Old 05-21-06, 02:39 PM
cartechpr
cartechpr's Avatar
You might want to check what codes its giving... it will turn on with a MAF Code.
KDHarbour
ES - 5th Gen (2007-2012)
04-26-21 10:44 AM
Creamer60
08-06-17 10:22 AM
pusan8
03-08-09 07:06 PM
daryll40
12-30-08 02:20 PM
chip99
07-31-06 08:02 AM
Quick Reply: VSC Warning
