90-92 Remote Key Battery Number?
Old 03-18-06, 02:14 PM
Kemo
Kemo's Avatar
Default 90-92 Remote Key Battery Number?
HI,
Could someone provide me with the battery model/brand number inside the remote key? I took mine out to get a replacement but I lost it.
Old 03-18-06, 03:25 PM
agasfer
agasfer's Avatar
Originally Posted by Kemo
HI,
I just tried to do the same: removed the screw which is close to the key shaft, but the plastic enclosure would not split open - it seems to be held together by something on the other side of the key head (where the elongated key ring hole is). I did not want to force it, being afraid to crack it.
Did you have any problem like this opening up your key? If you let me know and if I manage to take mine apart I'd sure tell you what the battery part ID is
Old 03-18-06, 04:16 PM
agasfer
agasfer's Avatar
Actually I just browsed the forum a bit more and found out that what I suspected was true - needed just to try harder sliding the key cover to get it open.
the battery in my gs430 key is Panasonic CR1616.
Old 03-18-06, 04:56 PM
Kemo
Kemo's Avatar
Thanks, but My car is LS400, I don't think it is the same battery!!
Old 03-18-06, 05:03 PM
Kemo
Kemo's Avatar
Found it under
http://www.lexus-parts.com/partlist....=22&ModelID=60
CR1216 - Remote Lithium Battery
Old 03-18-06, 07:10 PM
CUMan
CUMan's Avatar
CR 1216 is the correct battery for your model LS. The price at Sewell is $1.00, but you have to pay shipping charges. This battery is available at Radio Shack for about $3.00.
Old 03-28-06, 09:56 AM
trukn1
NELOC Mod
trukn1's Avatar
Found it under
That battery is the correct one. You can also get them at your local WalMart at the jewelry section. It is a watch battery.
babbles
HS 250h Model (2010-2012)
10-31-17 06:05 PM
Jordo609
10-31-11 02:25 PM
revoappare
08-16-10 05:43 PM
illmike
06-22-09 04:03 PM
dysLEXic
IS - 1st Gen (2001-2005)
01-21-09 09:07 AM
Quick Reply: 90-92 Remote Key Battery Number?
