More information on this mod
The Green Grundel
Well, I found what my next saturday is going to be deticated to:
Does anyone have any information on how this was done?
I assume I have to cut the housing and put the projector in, are those the high beams or the low beams? What happens to the auto-leveling system?
This is off topic but I saw your thread on vipstylecars and I noticed that d2 sells a very similar style http://www.d2autosport.com/mrr.html the forth one down. Hopefully this helps. p.s. check out the gs pics on the page, pretty clean.
BahHumBug
im pretty sure its just a standard retro, i think tiguy wouldnt have a problem pullin that off for ya
find the projector that you want, take measurements
see if those measurements fit inside the headlight housing you have
of course it's a little more complex than that, as far as fitting the projector and having the appropritae light output.
you lose the auto leveling, as there are gyros in the suspension that feed through the ecu and to the headlights.
rukarims
04-19-03 09:44 AM
