Ls/400 Cluster Lighting
Old 02-28-06, 08:53 PM
JHP
JHP's Avatar
Post Ls/400 Cluster Lighting
Hi, first time on this forum. I have a 93 LS 400 with 116.000 mi My eyse are tired reading all the info on the 400s. My instrument panel won't light up in the cold weather. It finally does when the interior of the car is warmed up. I have read so many threads about this and now am not sure who or where it can get fixed. The dealer tells me you have to buy a new one for $1500. Sounds a bit much. Does anyone know if this will stay the same or finally die completely. And I have read that you can buiy from toyota much less expensive than lexus. I need to replace timing belt, w/pump, struts , ball joints and don't know what else until it gets taken apart. Can someone give some guidence on theses topics. PS. What grade oil should be used, I have a little valve noise I beleive, I have been using castrol 5-30 Thanks, JP : :
Old 02-28-06, 10:15 PM
Phucanese
Phucanese's Avatar
yeah, i have the same problem with my 93 as well.
i figured out 45degrees. if its above that, the lights will turn on right away
if its 44degrees, it takes a minute or two to turn on, and it prgressively gets
longer to turn on the lower the outside temperature is.
i dont know why the temperature would play a role in my gauge lights working or not.
Old 03-01-06, 03:00 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/40025-instrument-cluster-circuit-board-is-bad-1000-bucks.html
If its anything we discussed so much, its the cluster problem on the first gens. So many info can be found with the forum's search feature.
Welcome to Clublexus
Old 03-01-06, 09:48 AM
JHP
JHP's Avatar
Thats what happens to mine. The colder it gets the longer it takes to come on.
Old 03-01-06, 09:49 AM
KilaWombat
KilaWombat's Avatar
I also have this problem on my '93
Old 03-04-06, 01:34 PM
money444u
money444u's Avatar
Default jim walker is the one for you
I have a 1994 LS400 with the same problem I went 2 years with this problem untill I found Jim walker. I sent him My light cluster, he repaired it, I installed it when it came back to be, and now it is in perfect cond. If you need his e-mail just let me know.
money444u@hotmail.com
Old 03-12-06, 09:11 AM
Lexs400
Lexs400's Avatar
yup,
common issue on the 93-94LS400's.
my 92 did not have this problem. It's a small electronic component that costs 80cents. just needs to be replaced !
do a search and you'll find all that info.
good luck.
Old 03-12-06, 09:44 AM
KilaWombat
KilaWombat's Avatar
money444u ... what was the cost to have jim walker fix this? whats the total cost including shipping?
Old 03-26-06, 10:09 PM
vinegaroon
vinegaroon's Avatar
Default Cluster fixes
Contact jimlwalker@sbcglobal.net about the illumination problem. He repairs the boards
and guarentees his work for a very reasonable fee.
New information: Have now found www.mrwizard.com who also does all cluster work including speedometer and tach for a reasonable price with guarantee. Check it out.
Kuyajoe
04-04-17 12:38 PM
tjschraf
10-07-11 09:57 PM
jdmcelsors
01-18-08 09:58 AM
Quick Reply: Ls/400 Cluster Lighting
