What is this hose on the top of engine??
Old 02-20-06, 09:12 AM
reuvenh
reuvenh's Avatar
Default What is this hose on the top of engine??
Can you guys please help me identify where this hose goes to? The hose comes out (or in) from the top front of the engine right under the word Lexus and under the brake lines going to the traction control module. I have a 1990 LS400.
It looks like a vaccum hose but is currently just hanging loose down by the steering pump area but I truly have no idea what it may be.
Thanks!
Attached Thumbnails What is this hose on the top of engine??-photo_022006_003.jpg
Old 02-20-06, 09:45 AM
damon
damon's Avatar
It runs to the power steering pump. Specifically the Idle Air Control valve.
Old 02-20-06, 11:32 AM
reuvenh
reuvenh's Avatar
Damon,
Thanks for the quick reply. It has been disonnected for some time now - could I have done any damage to something?
I presume there should be only one empty inlet on the PS pump that this would attach to. I will check it out in an hour or so...
Old 02-20-06, 12:54 PM
Caoboy
Caoboy's Avatar
plug both of them. cap off the hose, and the plug on the pump. its fine without it. actually better without it.
Old 02-20-06, 09:25 PM
damon
damon's Avatar
I don't have an IAC on my PS pump. My LS is plumbed like Caoboys & works fine. You have to have a block to keep the maf sensor happy.
Old 02-20-06, 10:07 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
hey damon, before u plugged ur IAC did u have a high idle on cold start? mine starts and idles round 1100-1200 rpm on cold start.
thnx. and sorry to semi-jack ur thread.
isaiah2011
08-14-11 09:56 AM
bdshomes
03-12-11 10:34 AM
LSCD
18
05-25-10 08:34 PM
SC400-V8
Maintenance
12-01-05 08:06 AM
Shaffer
11-29-03 08:39 PM
Quick Reply: What is this hose on the top of engine??
