Inside headlight dirty??? 2000 LS 400
Old 02-16-06, 10:53 AM
inspector1
inspector1's Avatar
Default Inside headlight dirty??? 2000 LS 400
Help! I have noticed one of my headlights has a significant amount of dust and/or what appears to be fingerprints....(must have been that way when I bought it)
How in the ____ do I take apart a light and clean inside? Are they meant to come apart?
Any help or guidance would be appreciated.
Thanks much
Old 02-16-06, 11:05 AM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
This is for a '90-'94 LS, but it's basically the same idea for yours:
http://www.cureline.net/lex/howtos/h...t_cleaning.htm
Old 02-16-06, 05:36 PM
Kansas
Kansas's Avatar
I question whether this process would work for a 98-00 LS. The gen 1 LS400 has a thick glass headlight lens which controls the beam pattern. The 98-00 headlight has a very thin plastic lens which has nothing to do with the beam pattern.
Old 02-16-06, 06:11 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the theory is the same of heating the unit so the glue melts and u can pry the halves apart. the SC guys do this all the time for retros, as do the GS guys.
Old 02-17-06, 10:46 AM
inspector1
inspector1's Avatar
Default Thanks
Thanks PureDrfiter for the insight. Sounds like a hassle, but fairly easy.
Old 02-17-06, 12:01 PM
mkorsu
Zombie Slayer
mkorsu's Avatar
SC guy here that can attest to the fact that the oven method does indeed work with no ill effects. It's a slow, methodical process. But not necessarily hard.
Old 02-22-06, 09:38 PM
ernpob
ernpob's Avatar
Make sure the dirt is on the inside. The dirt/stains might be on the outside. Rub some polishing compund on a small part on the outside and se if that fixes the problem.
foodbear
02-16-18 09:20 AM
tangcindz
12-14-16 05:34 AM
VQT
09-01-08 02:18 PM
flawdaboi
Lighting
02-08-05 03:54 PM
Lexs400
09-26-04 12:15 PM
Quick Reply: Inside headlight dirty??? 2000 LS 400
