need help with 1st gen ls4
im trying to get into the center console of my 1st gen. ls4 so that i can change my head unit. i dont even know where to begin. can anyone help me with this?
i could also use some help with taking out the the right cd changer housing. i would like to use the space to 'glass an amp rack. thanks for any help.
Welcome to clublexus,spkyedawg.
1.Pull the out wooden piece that surrounds the shift ****.(make sure you are in neutral)
2.Pull out the ashtray and them you will see two screws on the left and right side.(remove them)
3.use a flathead screwdriver and pop lose the airconditioner vents on the top part of the center consle.(remove the enitre unit that contains the air con. vents)
4.You now will find to more screws,again on the left and right side(remove those)
5.Then the radio and air con. control panel can be removed.
This is the fastest way to remove the center consule.
As for the CD changer dido?
Great you live in Irvine spykedawg.One of these days you can join our TeamLexstacy/Clublexus meets.Our meets usually start in Irvine or Tustin.
Give me your e-mail and I could notifiy you.Could you more LS's in our meets.
Feel free to ask anything here from Engine Mods to Radios,whatever someone will know of something.
Aristo94
11-01-06 09:44 PM
aids21
04-02-04 09:08 PM
