How to properly raise Idle on 95 Lexus LS400?
My idle is a bit low around 450-500rpm. I would like to raise it up to about 700 How will I go about doing that? What are the steps?
Thanks Alot!
Thanks Alot!
Thanks Alot!
Thanks Alot!
[QUOTE=MeanLex]If it's idling too low you probably need a new ICV (Idle Control Valve) and perhaps new plugs and wires.[/QUOTE
How many rpm's should my car be Idleing at? What should be my first step?
[QUOTE=DroppedGS]
should idle around 750rpms. clean out your throttlt body and run some b12 chemtool or seafoam in your gas after you fill up and that should raise your idle
[QUOTE=sha4000]
Ok Thanks I will give it a shot.
My '95 idles really low too. I've cleaned my tb, have pretty new plugs, used injector cleaner, etc. My IACV works fine because my car idles at 600-700rpms with the ac on. How does one adjust the throttle body? I can seem to find any info in my repair manual about increasing the idle speed.
Sha, perhaps the 98-00s idle faster because my repair manual says that my '95 should idle at 650 rpms +/- 50rpms.
Originally Posted by sha4000
blake are you a member of the LOC forum?anyway you are probably right try cleaning your MAF sensor also
porshapowe
14
03-21-19 09:21 PM
