Light Out On Climate Control
Old 01-16-06, 10:01 PM
vuman1
vuman1's Avatar
Default Light Out On Climate Control
Anyone know to change out the bulb on the small LCD climate (temperature) control on the 1988 LS400? I would appreciate if someone could tell me how to take the thing apart to get to the bulb. Thanks.
Old 01-16-06, 10:10 PM
PVSLS400
PVSLS400's Avatar
its fairly easy to fix i will post pics tomorrow as soon as my stock of bulbs come in from Jim Walker. I will have a few hundred in stock since they work for so many applications and my whole family drives the LS. i go through about 15 a month. Let me know and i can either get you to Jim or i can through a few youre way
Old 01-18-06, 10:01 AM
vuman1
vuman1's Avatar
Pls let me know when you have the bulbs and please do post the pics on how to change it out. Thx.
Old 01-18-06, 10:45 AM
PVSLS400
PVSLS400's Avatar
Bulbs Are Here Pics To Follow
Old 01-18-06, 11:44 AM
PVSLS400
PVSLS400's Avatar
picture 1 pull vents out unclip hazzard plug
Old 01-19-06, 08:14 AM
PVSLS400
PVSLS400's Avatar
pop out lighter console
Old 01-19-06, 08:15 AM
PVSLS400
PVSLS400's Avatar
there are 4 screws to remove radio and climate control assembly. 2 behind vents and 2 behind cig lighter
Old 01-19-06, 08:17 AM
PVSLS400
PVSLS400's Avatar
next pull out radio and climate control there are 4 screws on taking climate control out 2 on left 2 on right spread out metal binder on each side and climate control will come out disconect wires on back of climate control
Old 01-19-06, 08:36 AM
PVSLS400
PVSLS400's Avatar
once you have the climate control completely out of car there are 2 screws on the front side of unit 1 on the left one on right + 4 tabs 2 on top 2 on bottom use flat head and pop the tabs and front of climate control will come off
Old 01-19-06, 08:37 AM
PVSLS400
PVSLS400's Avatar
once you get face off climate control it will look like this
Old 01-19-06, 08:42 AM
PVSLS400
PVSLS400's Avatar
This is the housing for bulb, use small phillips turn counter clockwise and use flat head and bulb will come out. pull off green boot and slide green boot on new bulb . I recomend you do all bulbs at the same time so you wont have to do this in a month or so.
Old 01-19-06, 08:45 AM
PVSLS400
PVSLS400's Avatar
this is what bulb looks like
Old 01-19-06, 08:48 AM
PVSLS400
PVSLS400's Avatar
new bulbs come like this
Old 01-19-06, 09:41 AM
JDMUSCLE
JDMUSCLE's Avatar
my climate control in my 95 LS is sometimes dull and i was thinking does changing the bulb fix this problem or i need to change the lcd screen!!
Old 01-19-06, 04:39 PM
PVSLS400
PVSLS400's Avatar
is the display black or just not bright?
NCDUB
03-28-09 10:15 AM
Bombsquad
09-18-07 10:44 AM
skpark70
SC- 1st Gen (1992-2000)
03-28-03 07:49 PM
dkny_112
08-05-02 06:30 AM
Quick Reply: Light Out On Climate Control
