Battery Voltage Problem? What Can Cause This Problem?
Old 01-16-06, 05:29 AM
DroppedGS
DroppedGS's Avatar
Default Battery Voltage Problem? What Can Cause This Problem?
My Voltage is 13.5 When I start it up & 12.5 when Warmed Up.. What could cause the Big volt mdrop? I also installed my Highout Put Alternator (170amps) and it still has low votlage (12.0 idle). So I installed my stock alternator to see if it was the High Out Alternator but it isn't. What could e the problem?
Ps.. I thought the car was suppose to charge at 14.4? Anybody had this problem?
Old 01-16-06, 06:24 AM
koolaidman
koolaidman's Avatar
dont worrie about it. its normal. cold starts engine tends to use more energy. and u used the battery. so it needs to charge up. the reason y u get 12.5v is that ur battery is basicly charged up and ecu is telling the alternator that it doesnt need much output.
and how old is ur battery. if u replaced ur battery ull see similar results
Old 01-16-06, 11:07 AM
DroppedGS
DroppedGS's Avatar
My Battery is new. Is there anyway that I can raise the Voltage? Because when I play my stereo (About 1500watts) it dims my lights bad and it goes down to about 10.5-11volts.
Ps.. I brought an HO Alt to fix the problem but it doesn't seem to help?? So im wondering if there is something else that could be done?
Old 01-16-06, 01:34 PM
PVSLS400
PVSLS400's Avatar
put a cap in youre sound system this will help keep system bumping and keep lights from dimming
Old 01-16-06, 01:49 PM
sha4000
sha4000's Avatar
please explain
Old 01-16-06, 03:12 PM
PVSLS400
PVSLS400's Avatar
Well if you put a capacitor on youre stereo amplifier it will keep a constant 12v to you audio system without pulling constant voltage from youre battery. The capacitor will charge up and feed audio system independently. Capacitor is a energy storage device designed to supplement a audio amplifier power supply during times of high current demands.Automotive batteries are not designed to deliver the instantaneous current required in high power car audio applications.
Old 01-16-06, 04:36 PM
sha4000
sha4000's Avatar
thanks for the explanation
YoungNas
16
12-10-18 04:13 AM
jean1982
09-22-14 11:37 PM
76mmturbo
Performance & Maintenance
07-12-13 07:52 AM
scENFORCER
SC- 1st Gen (1992-2000)
15
07-07-11 03:17 PM
SLVRGS
GS - 1st Gen (1993-1997)
02-03-04 11:54 AM
Quick Reply: Battery Voltage Problem? What Can Cause This Problem?
