1991 LS400 Woes :(
Old 12-27-05, 11:16 AM
irishae86
irishae86's Avatar
Default 1991 LS400 Woes :(
91 LS400 4.0L v8 - ex UK car I think (no japanese writing on the stereo) now used here in Ireland.
2nd hand car, private purchase.
Only have the ignition key/door key
No key FOB/no remote
No key for trunk.
Either trunk lock busted or need a different key for trunk.
Needs a paint job but with a Toyota 4.0 V8, looks werent a concern
Car was bought driving the finest needed pads on the front right, easy DIY job.
Locked the doors the first night, came out the following day and the car wouldnt start. Immobilised somehow, alarm wailing. Security light pulsed.
Pulled the battery and turned on electrics to drain any power. Left for 24hrs.
Replaced battery turned the ignition key, VROOM!
Great...made a note to never lock the car. EVER!
Car drive fine, security light stayed off.
until last night.
Locked the car by mistake, unlocked the car later and the alarm went off.
Put in the ignition key and the alarm stops, starter motor wont swing the engine over.
Pulled the battery again, but this time it did not work.
Car wont start, alarm goes off and security light stays on.
Tried it again, alarm is still a nusiance but the security light stays off.
Last attempt was to flatten a good battery and let the security ecus n stuff die!
All lights went out, even the security one. Jumped the lexus off another car.
NO ALARM sounded, this was good. Car still wouldnt start, IMMOBILISED.
Exited the car. Closed then opened the door, alarm went off.
-I need to know, with a fully charged battery in place, how do I reset the alarm and the immobiliser?
-Can they be reset seperately?
Irish Lexus dealers didnt sell the LS400 til 1995 or so I was told by a lexus dealer. So I'm screwed there cos they wont help. Found a 4amp fuse on a wire under the dash a a small switch by the accelerator pedal?? Its dark and Im not going near the car again til the morning.
If I can drive the car (immobiliser fixed) I can disable the alarm horn and get to where Im going.
NOTE: Found alarm horn, easily disabled
Happens to be a funeral at Christmas
Old 12-28-05, 05:23 AM
irishae86
irishae86's Avatar
Ok,
Can anyone give me an idea where in the engine bay I can tap into the starter 12v wire?
Im gonna manually switch it to get it started.
Anyone?
91 ls400?
Old 12-28-05, 05:17 PM
up675
up675's Avatar
the starter is hidden on that motor
Old 12-28-05, 05:44 PM
JDMFreak
JDMFreak's Avatar
the location of the starter is right between the heads, right in the middle of the heads, next to the transmission or near the firewall...you have to take off the head to get to it or pull out the motor
sorry if i am not explaining it correct
Old 12-29-05, 11:56 AM
hyperopt
hyperopt's Avatar
I taped into the fusebox under the dash (near steering column) when I installed aftermarket remote with remote start many years ago. Anti-thief device can be easily bypassed under the dash once you figured out the wirings, so schematic is a must.
LexusStevo
04-28-17 07:40 AM
Qwerty256
02-07-11 02:13 AM
Audacity
01-24-11 01:57 PM
Steveb44
11-28-10 11:04 PM
Muttley925
11-04-09 08:42 AM
Quick Reply: 1991 LS400 Woes :(
