1st timer here...help!
i saw the first post about the loose spark plug and i am going to go check it out on mine this evening! there is a slight ticking when the engine is running...sorry, it is a 92 lexus LS400...also, i contacted my buddy who is a mechanic and asked why the "TRAC OFF" and the ANTILOCK" symbols are up...he said it is probably just a dirty wheel sensor, or sensors...also the light indicating the brake light are out is on, did that come out right? well, he said a light must be out but none are, all of them work. he again said it is probably a dirty sensor or a bad sensor...i just got the ride with about 155XXX on it...it says on a sticker on the engine that the timing belt was replaced at 60XXX (actually like 57XXX) and i was wondering if anyone thinks i should get it done anyway...oh no!!!!can the ticking be related to a timing belt/chain on its way out? HELP!!!!!
by the way i am ever getting anything short of a lexus ever again!
right...thanks for the correction about the belt/chain...as for the "ANTILOCK" and the "TRAC OFF"
i live in ny and just this morning when i got on the gas to get the car out of some snow the wheels were spinning and in the center of the speedo "TRAC" flashed until the wheels caught the ground...i thought this weird that the "TRAC OFF" and "ANTILOCK" lights went away when the car lost grip....then the lights came back on..
here is where i am confused...if the "antilock" and the "trac off" lights are lit but they are the only lights that ever do lite up, is it still the oxygen sensors? or could it be a problem with a faulty wheel sensor?
now if i do have to replace the oxygen sensors to make the traction control work again, do i have to do ALL of the oxygen sensors? if not, which ones would i need to replace first to see whats wrong? oh, and where can i get a timing chain fairly cheap? one of my friends has a shop and can do it for me.
Since i work as electrician and also on computer diagnosis in workshop. Oxygen sensor has nothing to do with TRAC and ABS. I have tested inside out my 92 LS400. There are three probabilities.
1.) Damaged wiring or sensor (1 is enough) TRAC and ABS use the same sensor.
2.) Accumulated dirt on sensors use high presure washer to clean it
3.) Acelerator position sensor out of range. When wheel is skiddin On Board computer drops RPM acording to information supplied by this sensor if the information fails it swiches of TRAC,
now can i take the wheel sensors off a 94 or 95 model if my car is a 92? i am assuming i can.
should i go ahead and get them if i can? my buddy has a doner car for me to pick at...tires/wheels (factory), wheel sensors, ohhh! i should get the exhaust!,
off the topic----how many mies are their trannies good for with proper care?
Dutchy
26
05-15-13 08:07 AM
