DataSystem Manual
DataSystem Manual
Just got my DataSystem RSpec ASC680 installed. Does anyone have instruction manual for this thing? What are the recommended settings out there?
Is it better to leave the stock height sensor in the highest position?
Thanks
Thanks
I found this:
There are 2 modes on the height controller, Standard and Special. When you plug it in initially it will be on STD mode, which means the car can only go up and down to a certain "safety point".
There are 4 buttons, 2 on the left and 2 on the right. Simultaneously hold down the 2 on the left for a few seconds until the unit starts beeping. It should now say something like STANDARD in abbreviated form. Press the bottom button of the ones on the right to change it to SPL_ mode. You will always be able to tell what mode it is in by the horizontal line on the right. If it is at the bottom then it is in special mode.
Once you have selected that it will go to
H1 -000- You can have 3 pre-set height selections, with virtually any height you like. You have control over Front Left FL, Front Right FR, and Rear RR.
The first 0 is for the FL, next 0 is for FR, and last 0 for RR. 000 should leave the car standard.
The following is how it is set up in SPL_ mode 9876543210ABCDEFH (not sure if it goes to H). The higher the number the lower the car.
9 leaves the car on the bump stops F or H raises it up.
Play around with it until you understand it.
I know there are WAY MORE than this, but so far this is all I came across. If you find something, post it here.
Thanks,
Jim
Thanks,
Jim
Thanks Jim!
Any idea about where to set the height sensor setting of the car? I used to lower my car by trick the sensor and I'm not sure where the stock setting is now. Does it matter?
As for the settings, let's identify the buttons with (*) top left; (@) buttom left, (up) top right, (down) bottom right.
I know that the (up) and (down) toggles between the Normal mode and 5 memory settings. Once you toggle to a memory, you can press (@) to set the value for that memory with (up) and (down), toggle the different corners with the (@) and save the setting with (*).
I'm curious, is there a feature to override the soft/firmness of the suspension?
Thanks
Thanks
