Tanabe DF210 springs discussions (The Mother thread)
Old 11-09-05, 10:16 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
cutting your springs is honestly the STUPIDEST thing you could do to your suspension. most likely your running on stock shocks, which could need a bit of time to decompress to the point that the car is putting its full weight on the springs. i say give it a couple weeks. or, just do what your going to end up having to do sometime soon and put in a set of good aftermarket shocks.
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
Don't cut them. Wait another week or 2, they'll settle down a bit more.
Old 11-10-05, 12:26 AM
RA40
Super Moderator
RA40's Avatar
Definitely do not cut them. Call the shop that sold you the Tanabe's and ask what may be going on in your application. I've put springs into a handful of cars and those applications have gone almost exactly as spec'd once the car was set down. The last 1/8-1/4" occurs in 1K miles typically. How many miles on the new springs?
Any possibility that the stock springs may still be in front?
Old 11-10-05, 05:53 AM
sha4000
sha4000's Avatar
you didnt spend that money to have to cut the springs, if they dont settle take them back
Old 11-10-05, 11:52 PM
JDMUSCLE
JDMUSCLE's Avatar
i had it installed at a friends garage, see the only thing that gets me pissed of is the fact that the rear looks lower than the front.....the springs have about 200miles on them. i guess i will wait it out a little more or else i think imma get those bilstiens with different snap ring settings. thanks for the input guys!! i really appreciate it!!
-yogesh
Old 11-11-05, 07:46 AM
Celsior2K5
Celsior2K5's Avatar
Exclamation
Everyone who's asking if JDMUSCLE has stock struts...READ! He stated it in his first post.
Old 11-11-05, 08:43 AM
Stefwilli
Wheel Vendor
Stefwilli's Avatar
Are you using stock struts?...................................................
Sorry couldn't resist
Old 11-11-05, 10:42 AM
JDMUSCLE
JDMUSCLE's Avatar
is this a reason why my car doesnt look lowered....im confused here, i am planning on getting the bilsteins since they have different snap ring settings so i could have them adjusted to lower the car a little more!!
Old 11-11-05, 11:05 AM
Stefwilli
Wheel Vendor
Stefwilli's Avatar
I'll be honest with you, I dont know the specs for the tanabe springs but I remember when I had my suspension instaled I saw the difference right away. Did you notice a difference in spring length btwn your stock ones and your tanabe's? When the shop took out my factory springs I put the l-sportlines next to them to see if there was a difference in length and there was. The L-sportlines were shorter.
Here is a pic of my car before I lowered it. Thats right, I used to be the #1 STUNNA
This is the day after I lowered it.
This is after two weeks of driving.
Old 11-11-05, 11:11 AM
Stefwilli
Wheel Vendor
Stefwilli's Avatar
This is after 6 months of driving:
I hope this helps, maybe the car will settle like mine did.
Old 11-11-05, 12:13 PM
sha4000
sha4000's Avatar
your car def. sat down more after two weeks stef
Old 11-11-05, 01:06 PM
Brandicus
Brandicus's Avatar
stef that lowering is the kinky sex, you used the tanabe's??
Old 11-11-05, 01:18 PM
Caoboy
Caoboy's Avatar
why not save money and just get coilovers? alot lower, and a lot better handling.
Old 11-11-05, 02:45 PM
PureDrifter
BahHumBug
Forum Moderator
save money??!!?? Tanabe's and some decent shocks can be had for less than $650-700. the CHEAPEST Tein CS coilovers ive seen have been about $1,299.
Old 11-11-05, 03:06 PM
Caoboy
Caoboy's Avatar
ok so for 500 more dollars, you get better dampening, ride height adjustability, camber adjustment, and it can go WAY lower! and the ride is way better...wow a lot of lexus owners are cheap
Quick Reply: Tanabe DF210 springs discussions (The Mother thread)
