Warning lamp:Engine Oil Lamp, Catalyst Lamp, Radiator & Tail light lamp turning on.
Old 09-28-05, 09:00 PM
loveMyLs
loveMyLs's Avatar
Default Warning lamp:Engine Oil Lamp, Catalyst Lamp, Radiator & Tail light lamp turning on.
I have a '90 Celsior with 170,000km & just noticed that the Engine Oil, Radiator, Catalyst & Tail Light warning lamp turned on at the same time for a few minutes then off. I have checked the oil, radiator & tail light & they're all fine. Anyone had a similar problem?
Old 09-28-05, 09:21 PM
Pagong
Pagong's Avatar
Check the alternator...maybe going out?
Had the same problem when I first got my LS..
Old 09-28-05, 09:46 PM
qcruzer
qcruzer's Avatar
You might also want to the check the wiring harness that is strapped to the drivers side trunk hinge. Just pop the trunk and check all the wires there to make sure that none of them are broken. My car had this same problem, with most of the warning lights coming on and the transmission shifting roughly too. I found that this problem was posted in these forums before and I did have a wire that was broken. I spliced the wires together and have not had this problem since then...(going on two years now).
Old 09-29-05, 02:24 AM
loveMyLs
loveMyLs's Avatar
Default Warning lamps
thanks guys i forgot to mention about the battery lamp turning on too. i've got the feeling that it might be the alternator. i'll get it check tomorrow.
Old 09-29-05, 04:45 AM
ychachad
ychachad's Avatar
Most likely it is the alternator, but it could also be the serpentine belt that drives the alternator. Check the belt, and the tension on it. Slippage can case the lights to show as well, because the alternator is not functioning, as it is not turning.
Old 09-29-05, 09:17 AM
persian451
persian451's Avatar
that just recently happened to me.. its most likely your alternator..
Old 09-29-05, 10:19 PM
loveMyLs
loveMyLs's Avatar
yup its the alternator alright! it not charging while engine is running. would it be better for me to get it new or reconditioned (exchange)? does it cost a lot to replace? thanks for all your replies.
Old 10-04-05, 12:28 AM
loveMyLs
loveMyLs's Avatar
Default alternator
I finally took my car to get the alternator fix but my mechanic is having trouble finding the part. Does anyone know if its fully compatible with 1990 LS400 part number?
Old 10-05-05, 07:35 AM
DanielPBNY
DanielPBNY's Avatar
Unhappy sc400 rear break light socket
Brake light bulb lights up when I replace it with a new bulb and the lights are turned on but as soon as I step on the brake, the light out icon comes on and the light doesnt light anymore. When I check the light, I find it isn't bad, so I take it out, reinsert it and the process starts all over again. Any thoughts?
Old 10-05-05, 08:25 AM
Pagong
Pagong's Avatar
90-94 are identical when it came to the engine.
Old 10-05-05, 11:53 PM
loveMyLs
loveMyLs's Avatar
Default Alternator problem
Ok finally got it fix and its only the regulator that need replacing which only cost me less than AU$100. According to my mechanic the alternator of Celsior is different from normal LS400 of the same year. I will post a photo of the regulator soon.
Old 10-11-05, 05:40 PM
loveMyLs
loveMyLs's Avatar
Default Regulator pics
Here are the pics of the regulator that was replaced instead of alternator.
Attached Thumbnails Warning lamp:Engine Oil Lamp, Catalyst Lamp, Radiator & Tail light lamp turning on.-regulator_top.jpg
Old 10-11-05, 05:42 PM
loveMyLs
loveMyLs's Avatar
here's the other side
Attached Thumbnails Warning lamp:Engine Oil Lamp, Catalyst Lamp, Radiator & Tail light lamp turning on.-regulator_bottom.jpg
nallenium
04-09-23 06:26 PM
tbpup
12
10-11-16 02:11 PM
Toledo777
01-11-15 08:39 AM
afshin
07-14-12 05:47 PM
dean s
SC- 1st Gen (1992-2000)
10-04-04 07:49 PM
Quick Reply: Warning lamp:Engine Oil Lamp, Catalyst Lamp, Radiator & Tail light lamp turning on.
