Help with part needed
Old 08-15-05, 05:42 AM
CelsiorAUS
CelsiorAUS's Avatar
Default Help with part needed
Hi
As shown on lexls.com i need the metal ring surround for the stock 8 inch pioneer sub
" The part is described as "Speaker Assy Rear No 2" and refers to the speaker on the rear parcel shelf rather than the door speakers. The part code for this item is 86160-50100 which is almost the number in your photo. I am guessing that 86160-50010 is a manufacturing part which together with the bracket (number unknown) makes up spare part 86160-50100. "
I believe the sub is part 86160-50100 but i just need the mounting bracket as shown in the picture.
Someone has kindly offered me a subwoofer for just a bit over 100us so I just need a ring.
If any1 has one or can get one please let me know
Thnanks
Old 08-15-05, 01:58 PM
loveMyLs
loveMyLs's Avatar
Smile subwoofer
It might be hard for you to find this part as the subwoofer is in one piece except the plastic piece that hold the foam on top. the cheapest way to repair your old sub is to go and buy a new rubber sides "8 @ Jaycars for around $20 & you'll get 2 rubber & a glue. Remove the old one carefully & make sure its clean then put the new rubber & glue the sides including the plastic ring that seats on top of the rubber. Leave it overnight to dry with a phonebook on top (magnet on top) & you'll be sweet!
sunfisher
02-29-08 12:28 PM
jabbar2002
04-28-07 06:12 AM
hoops_24
SC- 1st Gen (1992-2000)
06-03-01 07:08 AM
Quick Reply: Help with part needed
