Help!!!!! Injector plug problems
While doing the valve adjustment on my 93 LS4 I removed the injector connections that had turned rather brittle after 12 years of use. All of the plugs are now broken and don't lock together like they used to. Does anyone know where I can find more of these plugs as a pigtail? I'd rather not pay $830 for a new wiring harness from the dealership and no parts stores around here sell a pigtail harness for it.
Did you check CARSON TOYOTA? They should have the ends that connect directly to the injectors. Not everyone has to have a complete harness, and if you are sure the rest of the wiring is okay, then I suggest trying Carson.
Couyldn't hurt!
Couyldn't hurt!
IneednSC
Performance & Maintenance
01-29-16 12:54 PM
