Filling my A/C - How??
Old 06-21-05, 12:28 PM
LEXkid
LEXkid's Avatar
Default Filling my A/C - How??
I am doing a fill myself with r12a from www.redtek.com
Where exactly do I screw it into? the blue or red port?
Any tips or advice would be appreciated!
Old 06-21-05, 01:50 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Always the blue one, its universal
Old 06-21-05, 05:05 PM
ssscarpone
ssscarpone's Avatar
If you dont have any knowledge on hvac you have no business buying or touching r12a or any other refrigerant.
Take it to a professional that can service it correctly, with the correct equipment, and not contribute to green house effect.
Old 06-21-05, 06:07 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Its a very small task, you dont need a degree to add R12a. You think he's asking because he doesnt know what he's doing, but in fact, there are two identical ports you can plug the wire into, the low, and high pressure. Sometimes they arent marked correctly, and you have to ask which is which.
Old 06-21-05, 07:05 PM
LexLS
LexLS's Avatar
Has anyone used this one: http://www.partsamerica.com/productd...tnumber=MAC134
Seems pretty simple to check and add.
Old 06-21-05, 07:08 PM
ssscarpone
ssscarpone's Avatar
But you arent allowed to even buy r12 without a cert.
And there is a reason it is low on r-12, and you should find it.
Old 06-22-05, 07:39 PM
LEXkid
LEXkid's Avatar
True about r12... but If you had read my original post thoroughly you would have noted the r12A . and the website www.redtek.ca
My car has already been retrofitted with r134a, but it has a slow leak. I will top up with the environmentally friendly r12a which is compatible with both r12 and r134a systems.
I have my answer on the low port now - thank you
Does anyone know the effects of mixing r12a and r134a??
thanks
Old 06-23-05, 09:56 AM
ssscarpone
ssscarpone's Avatar
thanks
Well if you would of read www.redtek.ca throughly you would of noticed that r12A! and r134a operate at different pressures and has different boiling points. In other words dont do it. You would have pressures that do not match with saturation temps and so on.
Old 06-24-05, 02:21 PM
LEXkid
LEXkid's Avatar
So I filled it and it is now ICE ICE COLD
I used the www.redtek.com r12a! So far so good after 2 hours lol... hopefully it'll last.
I checked the pressure before filling it with the guage and system was empty so its all good.
tinman
08-18-13 04:13 PM
BballMike
RX - 3rd Gen (2010-2015)
05-05-09 10:02 AM
DarKnight
01-06-07 01:40 PM
Quick Reply: Filling my A/C - How??
