Transmission Cooler
Old 06-01-05, 09:21 PM
bicol-ini
bicol-ini's Avatar
Default Transmission Cooler
hi, does anybody installed an auxillary transmission cooler like hayden or B&W, or derale, so instead of running out of the radiator, this now to be rerouted to the cooler, any thoughts
Old 06-01-05, 10:16 PM
RA40
Super Moderator
RA40's Avatar
The guys in the GS forum have discussed this to some length. What I recollect is that for normal conditions, the factory set-up is more than adequate to handle the tranny heat. If you install a TC, tow or drive the car hard in a hot climate then you may see some benefits with a cooler.
Many cars are tested in Dealth Valley during development so for the most part, it is fine. If you are having tranny fluid issues or related heat problems, there is likely something wrong in the system that needs attention.
Old 06-02-05, 02:16 PM
Lexusfreak
Lexusfreak's Avatar
Cool
I agree.
Old 06-23-05, 01:44 PM
dre300
dre300's Avatar
Default Greddy
Greddy Makes One For The Sc300 Its About 350 Or U Can Go With A Fluidyne Multiflow Cooler With Is About 50 Bucks
Old 06-23-05, 02:16 PM
bicol-ini
bicol-ini's Avatar
hi, i installed a B&M supercooler part#70264 couple of weeks ago, went smoothly, infront of the radiator right side if your facing the car, along with these i replaced the filter, clean out the shift solenoids, installed a new gasket, then on with the tranny flush, after 7 quarts got all new fluid in the tranny (red T IV), after all is said and done test drive it ohh what a difference, no more the once in a while jerk you experienced id say a
harrisbaig
04-19-19 05:38 AM
CrystalGS3
08-02-09 10:51 PM
KevinGS
05-07-06 12:14 PM
Goldark
Performance & Maintenance
12
07-01-05 10:01 PM
Carbon J
01-06-04 01:27 PM
Quick Reply: Transmission Cooler
