Suspension/driveline
I have a 1991 LS400, I can hear a clunk over bumps in the right front. The dealer checked it and said I need a new front upper control arm and a rear upper arm also. They said you can't replace the ball joint seperatly because the ball joint is not available without the whole arm. These arms are quite expensive and I would like to fix this when I put my new Eibach/Tokico suspension kit in at the same time. Any one have any ideas or dealt with this. Also I'm getting a vibration and they said I need a new drive shaft, real expensive! any ideas?
Thanks.
Thanks.
I would wait and see what your new control arms do first before the drive shaft. Usually, worn out bushings "which is exactly what you have if you're hearing the famous Lexus clunk" creates vibrations as well. I've got a 95 and getting ready to replace all my control arms. I've got vibrations as well. Don't think I've heard anyone needing to replace the propeller shaft unless they've broken in half.
SNiiP3R
02-26-20 10:31 AM
