Thanks To OVERSTEER!
I have been trying to find the looseness in the front passenger suspension for some time now. I had my shocks and mounts replaced but this wasn't the problem but at 60K and eight years old it probably wasn't a bad idea to replace. After checkig as many bushings as I could I checked the tie rod ends and they seemed loose. I saw the tutorial by OVERSTEER ( CL member ) R&R ball joints and tie rod ends so I thought I would try it. The job was not hard. I did the right side in two hours and I had never done this before. The looseness is GONE and I couldn't be happier. I highly recommend this fix to us guys with older LS'S, mine is a 98. So a big thank you to OVERSTEER. Mark
