Help Boot leg cds wont play in my 95 LS400
Old 04-18-05, 08:51 AM
jersey1
jersey1's Avatar
Default Help Boot leg cds wont play in my 95 LS400
Its seems like bootleg cd give me problems in my changer. When I hit the brakes or turn left or right I get alot of static and then it stop playing. Is that what the problem is or is something wrong with my cd changer? I seems to play alot better with the orginal cd. Help
Old 04-18-05, 09:20 AM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
It's most likely the quality of the bootleg CD and not your CD changer. Any idea what brand they are?
Old 04-18-05, 12:00 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
So this only happens with burned CD's? If yes, then you should try to get some high quality stuff.
Old 04-18-05, 09:23 PM
RA40
Super Moderator
RA40's Avatar
Does the boot leg play in your other players?
I burn discs regularly and unless there was a burn problem or bad disc, they work in mine. YMMV of course.
Old 04-28-05, 01:21 PM
Lexozz
Lexozz's Avatar
It is very possible that your changer is going bad. I burn a lot of CD's and in the past they would play with no problem. Now sometimes they don't play at all. Only the orginal CD's play good well at least sometimes.
Actually, when I buy brand new CD's the 1st or 2nd track skips and sounds like its scratched. I've come to the conclusion that it's time to replace the entire system. It's about ten years old!
Old 04-29-05, 07:47 PM
Brian S
Brian S's Avatar
I have a problem with weird scratchy-skippy sounds when I play memorex CDRs. This happened in my former 99 GS, and also with my 98 LS. I think it's the pioneer player.
Brian
Old 05-03-05, 08:32 AM
jtparkes
jtparkes's Avatar
Sounds like changing the CD would be the first thing to try.
I had that problem at first with cd's in my Pioneer system in my '99. I was told the solution is to buy the best CD's, which I found was good advice. Memorex sounded like a vinyl LP would sound with a cat fur-ball under the needle, the TDK's were better but still not acceptable.
However, Sony's work just fine (they are also the most expensive). I don't know if its relevant, but they are very darkly colored.
I am not condoning illegal bootlegging - I put some of my records on CD to listen to in the car.
Jeff
Old 05-03-05, 10:22 AM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
I had the same problem when using Memorex CD-Rs. Never had any problems after I switched to TDK Music CD-Rs.
I've noticed the same thing too. It seems like the darker colored ones read a lot better than the lighter/translucent ones.
Old 05-03-05, 06:43 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Yup, Black CDR's seem to last much longer.
Old 05-04-05, 12:47 AM
Lpham_3
Lpham_3's Avatar
Jeff
i "back up" my cds to play on my changer
Old 05-04-05, 04:18 AM
Lsportline43
Lsportline43's Avatar
I use to burn CD-Rs a lot for my MP3 CD Player. I use to use Taiyo Yuden CD-Rs. They are known to be the best CD-Rs. This company created the CD-R. When using these CD-Rs I never had a problem. Also it could be the burn speed that causes the bad CD-Rs. I recommend burning at below 24x if possible. I usually burn at 12x or slower if I have the time.
By the way I believe you can get Taiyo Yuden CD-Rs for cheap on eBay.
LSLex
23
02-24-12 01:23 AM
ravig292
07-12-11 11:59 PM
kappa54
10-03-07 12:06 AM
Shnerez420
08-11-04 08:58 AM
Quick Reply: Help Boot leg cds wont play in my 95 LS400
