Cabin Air Filter
Old 03-24-05, 11:17 PM
prep2
prep2's Avatar
Default Cabin Air Filter
I finally located the cabin air filter for my LS400 1994!!! The diagram applys to the 89-94 LS400s. See attachment.
Old 03-24-05, 11:33 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Actually, they were only avaliable in 1993+
Old 03-25-05, 05:38 AM
PK_Lex
PK_Lex's Avatar
What is the time duration when this filter should be changed? What is the function of this filter?
Old 03-25-05, 07:26 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
It filters up the air going into the cabin through the AC vents. Depending on Climate and individual needs, I would estimate about roughly every year.
Old 03-25-05, 12:33 PM
prep2
prep2's Avatar
lexus says they recommend every 15,000. However the instructions say you can use a blow air to clean them out so then you might be able to get a little bit more out of them.
prep2
prep2's Avatar
They filter air coming from the outside right?
Old 03-25-05, 01:44 PM
PK_Lex
PK_Lex's Avatar
Thanks for the info.
Old 03-25-05, 03:49 PM
Christian
Christian's Avatar
Hello,
is it possible to switch the parts to make the filter fit in a 92 LS?
Chris
Old 03-25-05, 05:23 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
yes, from outside, and recalculated air from the inside.
Old 03-25-05, 05:25 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Originally Posted by Christian
Hello,
Chris
I think there was some discussion about this in the SC forums a while ago, and they determined it wasn’t easy due to different design, but I’m not entirely sure about the LS, but I don’t know of anyone who successfully done it.
Old 03-28-05, 07:44 PM
Janeth
Janeth's Avatar
I did this about a year ago. It was fairly easy to do and there was a huge improvement in the airflow coming through the vents after doing this.
Old 02-15-06, 11:39 AM
91LS400vgb
91LS400vgb's Avatar
I'm interested in adding a cabin air filter to my 91 LS400. I see in the previous post that someone has done this. Could anyone expand on what parts I need and what steps I need to take to do this? Thank you.
Old 02-15-06, 12:09 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
As it turns out, most Lexus models came with the location for the filter, but just didnt have a filter installed. So check if your 91 has a place where the filter can be inserted, and if you do, all you have to do is buy a filter and install it.
Old 02-15-06, 02:41 PM
91LS400vgb
91LS400vgb's Avatar
WOW, I hope you are right. I will check. Thank you.
Old 04-11-06, 01:48 AM
mann777
mann777's Avatar
Default Cabin Filter Change
The manual recommends at 140mile . I happened to do it, and teh stuff was full of dust, geez !! The cabin now get cold in few seconds and sometimes i shudder !!! My 94 has not been changed from teh delivery date !! Now the cabin cooling is great !!! I recommend to all LS First Gen to go for it, if it is not changed.
Quick Reply: Cabin Air Filter
