Upper control arm bushing replacement Kit
Old 03-23-05, 12:48 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Default Upper control arm bushing replacement Kit
I have seen a lot of Ebay sellers that don’t know what they are talking about, so I wanted to know if anyone here has tried these, or has any opinion about them, and if they really fit my 98. Because im about to do both sides.
They are not cheap, but cheaper then $320 per Arm. I would be able to do the both sides of the upper, and lower control bushings all for less then the price of one arm.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33583
Thanks guys
Old 03-23-05, 08:49 PM
prep2
prep2's Avatar
I don't know about them. Might want to first check and see if you need to replace your bushings. I think you jack up the car and jerk tires around and see if there is any play in them. Also, I did the daizen front control arm bushings on my LS400 94' and they tighten the front end up but they do SQUEAK (first started squeaking about 2 months after install) and installation is expensive. Can't hear the SQUEAK if radio is on though.
Might recommend VTFBUSHES which are OEM like and have to be pressed in to your current control arms.
Old 03-24-05, 04:05 PM
bicol-ini
bicol-ini's Avatar
hi, part number should be ADUS 502 for the upper control arm bushing kit, same manufacturer for the rear carrier bushing ADUS 505, if it is then thats it,
dashan
06-27-18 06:48 PM
midwest2
05-13-12 10:52 AM
bacardi
02-17-12 08:06 PM
aristo123
11-10-11 05:21 AM
AZGS4
Suspension and Brakes
16
11-11-09 04:37 PM
Quick Reply: Upper control arm bushing replacement Kit
