Removing the Trunk Emblems *need help*
EV ftw!!!
Good old search function is very effective!
https://www.clublexus.com/forums/sho...moving+emblems
Originally Posted by LexusRules
hey man, use a blowdryer on hot and some tooth floss and just move it in a saw motion slowly keeping heat on the emblems and it will come off, then you need to get rid of most of the residue. Since you are putting the identical embelms back on but different color removing all the residue may not be tottally neccessary because it will help you with knowing where to put the new emblems
[QUOTE=Hameed]Good old search function is very effective!
7 post give the guy a break!!
Depending on the year you might have some prongs to deal with. the gen1 had prongs wth rubber inserts in addition to the adhesive. To get all the adhesive off use rubbing alcohol, a rag, and some elbow grease.
EV ftw!!!
If I had just said "search function is effective, use it" and not posted in those urls, then your comment would have made more sense.
3UZ-FEEEE
The way you responded was a bit sarcastic.
Just in the past 2 weeks alone, i've seen a good 4-7 "Should i get a 300 or 400" threads.
