Time for new shocks?
Old 02-07-05, 01:50 PM
psls400
psls400's Avatar
Smile Time for new shocks?
Hi Guys
My 91 LS has almost 300,000km's on it and is going strong.
I am second owner and note from the service history that the shocks (non-air susp) have never been replaced.
I am probably answering my own question, but should i replace them and with what?
Regards
psls400
Old 02-07-05, 03:53 PM
bicol-ini
bicol-ini's Avatar
hello your choice, OEM you retain the original ride, KYB and TOKICO are also available, but a little stiff, so you decide and the availability and cost comes into play
Old 02-08-05, 03:18 AM
Christian
Christian's Avatar
Hello,
I would use the springs, shocks and rear strut from the 93-94 model.
Chris
Old 02-08-05, 03:12 PM
xirforever
xirforever's Avatar
How much would KYB or TOKICO shocks cost? Any good websites that sell them for the LS first gen?
Old 02-08-05, 03:34 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
psls400, is the ride quality bouncy at all? You should try pressing down on your trunk then releasing it immediately and see how long it takes for the car to regain stability....if it bounces more than 2-3 times, then that's a good sign that your rear shocks are out. You could try the same method for the front shocks as well. With the amount of mileage on your car right now, I would think that the rears might have gone out or are close to going out.
Tokico shocks go for $75 per shock at TM Engineering:
http://www.tmengineering.net/suspens...ake/lexus.html
Old 02-15-05, 02:05 PM
DTT
DTT's Avatar
Default shock for 91 LS
My 91 LS has 200K miles on it, the shock absorbers are still shocking decent. If you have to change to new shock and plan to keep the car for times to come, I would buy the original one.
Old 02-15-05, 05:06 PM
vicpai
vicpai's Avatar
Thumbs down I just replaced shocks on my LS....
.......but I'm not very happy with the result. My car has about 65K miles and I was told by the Lexus dealer that my front shocks are on their last legs. So I went with BILSTEIN shocks at all 4 corners, as I had heard a lot of good things about them.....After the replacement, the Lexus "magic carpet" ride is gone, making the ride a bit harsh when hitting potholes or going over bumps. Handling has improved a bit, but I don't think it was worth the ride tradeoff!!
Old 02-16-05, 03:38 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Which Bilstein's did you go with? If i remember correctly there were normal, and heavy duty ones. At least for other cars there was.
Old 02-16-05, 11:56 AM
vicpai
vicpai's Avatar
Default I went with the....
.....Heavy Duty (HD), which, as far as I can recall were the only ones listed for my particular model year. the ride's not too bad most of the time. Only when I hit a pothole or go over a sharp bump.
zeez88
07-13-23 01:20 PM
1WILLY1
02-11-14 08:58 PM
bruceb58
Suspension and Brakes
05-26-09 09:32 AM
nstokes
09-12-06 11:07 AM
rd8a
07-12-02 06:04 PM
Quick Reply: Time for new shocks?
