Rewiring your fogs in 95 LS400
Old 10-23-13, 07:13 AM
  #46
Boomer9094
Boomer9094's Avatar
My concern was having the fogs turn off with the car. so no dead batteries. I did this mod as it was written and they worked but not from the fog light stalk. and only with the headlights off. and I put a switch inline with the power wire
Old 10-23-13, 07:56 AM
  #47
spinout180
spinout180's Avatar
Hmmm... hard to fry those relays... sure you didn't blow a fuse somewhere?
Old 10-23-13, 09:01 AM
  #48
Boomer9094
Boomer9094's Avatar
fuses all good relay stopped clicking. I did have an issue during the hot spell and my fogs stayed on for several hours. with headlights and car off. I thought it might be sticking in the relay from the heat. pulled fuse then and reinstalled a week later and have not had any problems. until Monday. going to look at it Thursday. when I get new relay. if still nothing then I don't know. but I did check all fuses right away
Old 10-28-13, 09:01 AM
  #49
LEXUSA400
LEXUSA400's Avatar
I just got an electrical wiring diagram manual for my 1997 LS400 and there is another option.
The Fog Light relay has 4 connections-
1. Constant Hot 12VDC from battery.
2. Wire to feed Fog Lights power.
3. 12VDC control power coming from LF low headlight feed. (This is why the Fogs only work with the headlights on)
4. Switch on stalk which provides ground to energize the relay.
On the main fuse/relay panel behind the battery there is a wire that runs from the LF headlight low beam fuse to the Fog Light relay under the dash to provide control power. This wire also sends 12VDC+ to the "Combination Meter", I think the light in the middle of the dash that comes on when the headlights come on. We can cut this wire and splice it into power coming from the tail light fuse or side marker light fuse, which is what the Canadian models have. I see no necessary purpose to the dash light telling me my headlights are on anymore than if my parking/tail lights are on so it would be lit when the tail lights are on.
I haven't lifted up my main fuse panel to take a look at the actual connector, pin position and wire but it is connector 2E, pin 1, a red wire. I'll check this out and see what color the connector is and how to easily identify it.
Old 01-08-15, 08:08 PM
  #50
python
python's Avatar
need a link to the 90-94 foglight rewire thread...thanks
Old 12-03-15, 05:28 AM
  #51
Shiryo
Shiryo's Avatar
So, with this writeup, would you be able to run the fogs on with the high beams?
Was messing with some new bulbs for several hours lastnight and I was bugged by the appearance of the fogs being off when my highbeams were on.
Old 12-03-15, 08:05 AM
  #52
python
python's Avatar
ur led kit by kensun?
Old 12-03-15, 08:39 AM
  #53
spinout180
spinout180's Avatar
Originally Posted by spinout180
Goal: Rewire the fog lights so that the factory switch controls them, but they can turn on independently of the headlights. They can be wired to turn off automatically with the ignition or the parking lights, or be completely independent.
Yup. The factory switch controls them independent of what the headlights are doing, so you can have them on if the headlights are on or off, brights or no brights.
Old 12-03-15, 11:17 AM
  #54
timmy0tool
timmy0tool's Avatar
the fogs going off when the high beams are triggered is intentional and a DOT regulation, but yes when you do this mod, it become independent of everything else so fogs stay on.
Old 01-11-16, 09:24 AM
  #55
Hiroshi12
Hiroshi12's Avatar
Since you already bumped this old thread ^^^^ I will too. Isn't it possible to simply wire your fogs to come on with the parking lights? Or, if that's not an option, maybe use a toggle switch?
Old 01-11-16, 12:56 PM
  #56
spinout180
spinout180's Avatar
Did you read the instructions in the first post? There are specific instructions on wiring the fogs to do EXACTLY what you just asked.
Old 01-11-16, 01:14 PM
  #57
Hiroshi12
Hiroshi12's Avatar
Yes, I did read it but I'm not trying to take apart the whole interior of the car. That's EXACTLY what I'm trying not to do.
Old 01-11-16, 01:47 PM
  #58
spinout180
spinout180's Avatar
Well it's a good thing I provided very specific instructions that only require a few screws, six bolts and one nut to be removed. I'm pretty sure you don't have to take apart the whole interior.
Definitely NOT worth bumping the thread, by the way.
angus
01-23-15 09:56 PM
JEL
09-17-12 04:41 PM
2JTsc300
SC- 1st Gen (1992-2000)
01-17-12 05:25 PM
horent135
08-05-08 10:21 PM
howiedoit
08-07-01 01:32 PM
Quick Reply: Rewiring your fogs in 95 LS400
