95-2000 guys, I have a break pedal problem
Old 11-01-04, 09:25 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Default 95-2000 guys, I have a break pedal problem
All right, first off, I have about 1.5 inches of break travel before my brakes would even engage. This is pretty much Dead space. Now I don’t remember when I drove other LS's because I didn’t pay attention, but is this normal? In addition, my breaks are kind of mushy. (Except first thing in the morning, they are nice and sold). The fluid is fairly new, as well as the pads. I wish I had another LS I can drive to reference this too.
Every time someone drives my car, they suggest my car needs new breaks, because you have to push it far down to get the break lights/breaks to engage. I searched the forum, and but did not come up with anything.
So to recap, I have 2 issues:
1) dead space.
2) 2) mushy feel after 15mins of driving.
Thanks guys
Old 11-01-04, 11:42 PM
RA40
Super Moderator
RA40's Avatar
My thoughts:
Master cylinder and/or brake booster.
Check to see that all flexible brake lines are not kinked or damaged.
Old 11-11-04, 01:49 PM
hyperopt
hyperopt's Avatar
Also, air could be in the system.
Old 11-13-04, 07:51 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
But the thing is, the break lights don’t even turn on until at least an inch of being pressed. That’s why I suspected it was some kind of pedal adjustment or something. Plus I don’t have any vibration problems at the pedal at all (knock on wood).
Old 11-30-04, 10:32 PM
audphile1
audphile1's Avatar
but you said the brakes are feeling kind of soft? have you just noticed this now or is it because someone told you that they felt like you need brakes after they drove your car? were rear pads replaced? are all the 4 rotors in good condition? are they thick enough or they have been cut so many times that there is not enough left of them. Check your rotors, make sure pads are not crap and I assume they are OEM and then bleed your brakes if everything else is fine. That, of course is after you check if there are leaks anywhere in the brake system. good luck.
dillon81
13
08-15-13 03:57 PM
NYG
Suspension and Brakes
27
04-28-13 07:45 AM
qwerty04
09-21-12 12:16 PM
Sup2jzgte
06-05-08 11:52 PM
Lexs400
10-09-03 10:14 AM
Quick Reply: 95-2000 guys, I have a break pedal problem
