removing rear view mirror
Old 10-04-04, 07:03 AM
RUDENESS
RUDENESS's Avatar
Default removing rear view mirror
How do i remove the rear view mirror in my 91 LS 400? I dont see screws so do i just ****** it off gently??
Old 10-04-04, 08:54 AM
LexLS
LexLS's Avatar
If you're talking about the inner rear view mirror then this should help you: http://www.lexls.com/rearviewmirror.html
leosls400
leosls400's Avatar
You need to remove the mini visor in the center just above the mirror to get to the screws. The cover goes over the mirror, remove by inserting a small flathead screwdriver between the mirror and the mini visor cover. Make sure you put some tape on the tip of the screwdriver to prevent any chipping of paint or damaging of plastic . After you remove the mini visor you will see two screws that hold the mirror.
Old 10-04-04, 08:58 AM
leosls400
leosls400's Avatar
Earl!, you sure are fast, you beat me to this. Follow Earl!'s instructions, very good pictures by the way.
Old 10-04-04, 09:05 AM
RUDENESS
RUDENESS's Avatar
thanks guys........
acotugno
RX - 4th Gen (2016-2022)
09-04-20 07:11 AM
CRuby
12-27-18 01:29 PM
suess15
ES - 5th Gen (2007-2012)
07-03-11 02:30 PM
horent135
SC- 1st Gen (1992-2000)
07-12-08 11:44 PM
Quick Reply: removing rear view mirror
