JDM Headlights
Well, I guess you could obtain JDM headlights from a 96 Toyota Celsior but they would be useless in the U.S. since the Japanese drive on the left side of the road. The beam patterns of JDM lights would really irritate other drivers and might get you stopped by the authorities quickly. The earlier LS with H4 headlights sold in the U.K. and Europe had a manual headlight beam level adjustment switch on the dash - similar to the current Toyota Sienna van with HID. Or at least they did through 1994 which is the last year of European spec LS with which I am familiar. I considered installing H4 headlights from the LS sold in Germany on my first LS about 12 - 13 years ago but it was far from "plug and play". It just wasn't practical to wire in the dash beam control switch.
Your 96 LS should have some very decent H4 headlights and with a pattern far better than the earlier LS. In fact the pattern is similar or maybe identical to the 96 LS sold in Europe. You might consider some of the non-coated Xenon/Halogen mixture H4 bulbs from Phillips, Wagner, etc. - they produce a very nice pure white (not blue) light and fill in the gaps in the beam pattern.
Originally posted by caliness
Thank you for your reply. My LS lights up the road very well, but I want to install an HID kit. Also, I want to go with the clear headlight lenses (which is the reason why I wanted the projector assembly). I don't like the look of the headlights anymore. I guess I just got used to seeing HID's everywhere!
Originally posted by Vik
What's wrong with old headlight assembly ? Can't you use HID with that ?
HID is not always better than Halogen. I was surprised when a couple of years ago a magazine - Consumer Reports or Road & Track - found that lots of cars with Halogen systems provide better light than cars with OEM HID. I thought it was rather funny that one of the cars with the best headlights was an inexpensive Mazda Protege. I suspect that modifying your 96 to HID will be an expensive mod with little or no improvement and perhaps provide even poorer lighting. And HID's without leveling can be blinding for other drivers - the DOT is considering banning HID without leveling systems.
Super Moderator
The beam pattern on the '95-'97 is pretty good even if it isn't the trend in lighting. I had an ES330 for 3 days and though it had self leveling HID's, the pattern was short and IMO did not provide enough even illumination. The color temp may be 4100-4200K but it appeared dim to me. High beam was a joke...threw light everywhere except where I wanted it. (Poor reflector design.)
I've taken my LS into the back areas when travelling through Oregon and along HWY1 in central and northern Calif and I think it does very well. Not very wide but it puts the light in front where I want it.
I want to see Lexkost's at night though.
The good HID's are illegal (8000+K). I'm not sure which intensity is the legal limit but I'm sure that's why the OEM HID's are not as good as halogens, it gets too bright for other drivers on the road. It's a catch 22.
I agree... I think the '95-'97 LS400's beam pattern is great... my Corolla's 9006 dipped beam illuminates just a tad better, but produce a good bit more glare to oncoming traffic. The main beam, on the other hand.... WOAH.... brightest lights on a car I've seen since my friend's old Mazda 323 GTX with four 100W lights mounted on the front bumper . The US LS400 headlights actually have a slightly farther throw than the Euro and JDM models, but not by much. It seems that Toyota took the superb E-code beam pattern and tweaked it just enough to conform to DOT regulations, which has resulted in an excellent set of headlights IMHO. And besides that, they're GLASS, which is unheard of in this day and age. What's not to love? Oh, and btw, the '95-'97 headlights use an H4 (60/55W) for both main and dipped beam, PLUS a 9005 (65W) for even more main beam punch. They also incorporate the 9006 (55W) fog lights... Toyota/Lexus put a great deal of research into these wonderful headlights, and it shows. So just get a pair of blue headlight bulbs and be done with it. I'll stick with my tintless Philips high efficiency H4s.
When you have the time, check out http://www.danielsternlighting.com/ ... everything you wanted to know about automotive lighting.
You're right about the lights, the 96 LS has the 3 different sets of lights in the headlight assembly and the H4 is low/high beam.
... and the H4 is low/high beam.
bellof.co.jp kit is a good one. All kits are in $1000 range.
You can get clear headlights from Japan but if you add HID it may cost you a fortune... Clear lamps for 2-nd gen are very rare... I think it maybe cheaper to upgrade your car to 98-00
Re: JDM Headlights
Does anyone know if there exists JDM headlights for the LS? I have a 96.
Wide LS,
If you bought something labeled JDM headlights and the beam patterns are for right hand drive, then you were not provided with "Japanese Domestic Market" (JDM) headlights. You probably have something made for some other non-U.S. market where they drive on the right side of the road - perhaps for mainland China.
