What happened?
Old 06-27-04, 01:31 PM
additude
additude's Avatar
Default What happened?
I had a rear light out indicator, which turned out to be a bad bulb for the brake light. So I pulled the bulb and figured I'd keep it out so I could take it in and buy a replacement.
I also had both fog lamps out, so I checked the right side and pulled that bulb. Initially I disconnected the connector for the air flow sensor and pulled the air cleaner out until I realized this was a remove the front lens and get to it that way replacement. I thought I had a good replacement bulb, so I plugged it in, started the car and turned on the lights. Still had a bad bulb.
After I started the car and realized I didn't connect the air flow connector back in, so I plugged it in and put everything back together.
Now I have a check engine light and the trac light is flashing.......what's going on with this?
What should I do? Pull the EC-1 fuse and reset it?
Thanks.
Old 06-27-04, 02:38 PM
RA40
Super Moderator
RA40's Avatar
I did the same on mine...I think I pulled both EFI fuses and it cleared the <check engine> light.
Old 06-28-04, 03:24 AM
additude
additude's Avatar
After I wrote my message I went back and started the car again, both lights came on then went out. That was the 3rd time I started the car after I re-connected the air flow connector.
It must have reset itself automatically after the 3rd start.....
I'm glad it wasn't something major.
Thanks.
xknowonex
SC- 1st Gen (1992-2000)
05-13-19 07:50 PM
willtan
RX - 3rd Gen (2010-2015)
08-28-16 08:57 PM
mnguyen072
01-27-15 10:02 PM
cannysage
GX - 2nd Gen (2010-2023)
15
09-21-10 10:35 PM
pgaedke
10-01-07 01:19 AM
Quick Reply: What happened?
