Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Sign in using an external account
Register Forgot Password?
90-91 Ls400
Thread Tools Search this Thread Display Modes
Old 05-29-04, 11:13 PM   #1
srg
Trader Score: (0)
Default 90-91 Ls400
Can the passenger side seat in MY90-91 be replaced with a later seat that has 10 way power?? Also what's the best size up for rims? 16 or 17? or? Best ride quality.
Pls advise.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
srg is offline   Reply With Quote
Old 05-29-04, 11:24 PM   #2
EXE.UCF10
VIP|EXEstyle セルシオ
Trader Score: (2)
EXE.UCF10's Avatar
It is unlikely that you will be able to fit a later model passenger seat into your '91 without some major modifications.
Stock wheels with stock tire sizes will give you the best ride quality. Going from stock 15's to 16's won't make as much of a difference in terms of ride comfort, but from 15 to 17+ will (due to the thinning of the sidewall of the tire as you move up in size and to more tire contact with the road if you're going with a wider wheel/tire). Just keep in mind that as you move up in wheel/tire size/width, you sacrifice ride quality.
__________________
Original image courtesy of spinout180
Special thanks to:
'Master P' Garage
Song's Tint Masters
TM Engineering
Essential Lites
EXE.UCF10 is offline   Reply With Quote
Old 05-30-04, 09:17 AM   #3
srg
Trader Score: (0)
Thanks Brian.
I had hopped to swap out the passenger seat with a later one. I would assume that the dimensions are the same and they woould sit on the same track.
Thxs also for the wheel /tire info. I'd probably go 16's max w/ a little wider Z's or W's.
Old 06-02-04, 01:02 PM   #4
jmblimo
Trader Score: (1)
jmblimo's Avatar
A '93 - '94 seat will go right in. You'll get most of the adjustments you're wanting (just like the driver's seat ) - big improvement over the '90 - '92 passenger seat. The later seat has a different electrical connector but I was able to pull the wires out of the newer seat connector and install them into the earlier item. The wire colors match up fairly well. A wiring diagram would probably help.
jmblimo is offline   Reply With Quote
Old 06-02-04, 03:28 PM   #5
EXE.UCF10
VIP|EXEstyle セルシオ
Trader Score: (2)
EXE.UCF10's Avatar
Quote:
Oops..I thought he was referring to 2nd or 3rd gen LS's when he said later models because he mentioned 10 way power.
'93-'94 models have the same adjustments on the passenger side as the driver side? Including lumbar?
__________________
Special thanks to:
'Master P' Garage
Song's Tint Masters
TM Engineering
Essential Lites
Old 06-02-04, 11:23 PM   #6
srg
Trader Score: (0)
Thanks guys. Interesting. Now I need a mint gray leather 93-4 passenger seat.
By the way, is the cushion on a 90 drivers seat soft and spongy feeling. Mine feels really softly sprung. Is that normal?? Moves a bit in hard cornering. Not the whole seat, just the cushion.
Old 06-03-04, 06:24 AM   #7
POS
Trader Score: (0)
My '90 seat feels soft and spongy too - with only 77k miles on it. I guess it's normal. I drove a '98 LS and loved the seats; much, much better.
__________________
2001 LS430
2002 LX470
1983 500SL AMG
1987 300E AMG
POS is offline   Reply With Quote
Old 06-03-04, 09:00 PM   #8
srg
Trader Score: (0)
Thanks POS. The spongy seat is only a drag in hard cornering. It also squeaks like bed springs going over bumps. I'll get used to it. probably shoot some wd-40 into the seat springs.
Old 06-03-04, 09:28 PM   #9
spxChrome
Trader Score: (0)
spxChrome's Avatar
Send a message via ICQ to spxChrome
Quote:
Wierd my 93 LS seats are hard as a rock. Guess they over compensated for the 90 soft seat
__________________
2006 LS 430 & 2004 RX 330
retired: 1999 ES 300, 1993 LS 400
spxChrome is offline   Reply With Quote
Old 06-07-04, 01:17 PM   #10
LeXuSrAcIn
Trader Score: (0)
LeXuSrAcIn's Avatar
Quote:
Same here... my 94 seats are like cardboard.
__________________
A Supra without a turbo is like a man without *********.
Current Lexus's
04 GX470
04 RX330
Past Lexus's
06 Lexus GS430 Glacier Frost Mica, 03 Lexus RX300 Pearl Diamond White
95 Lexus SC300 Pearl Diamond White, 94 Lexus LS400 Jade Green
LeXuSrAcIn is offline   Reply With Quote
Old 06-07-04, 04:24 PM   #11
spxChrome
Trader Score: (0)
spxChrome's Avatar
lol, exactly... mine feel like they are made out of plywood and springs.
__________________
Tags
90, 91, differences, ls400
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
