proportioning valve / abs actuator
Old 05-28-04, 10:32 PM
Lexs400
Lexs400's Avatar
Default proportioning valve / abs actuator
here's my question,
i'm trying to figure out if there's a way for me to totally bypass the abs system in the 93LS400. It seems like the ever going problem with the spongy pedal could be related to the abs system somehow. I'd rather be able to drive a car with good brakes than have the abs that doesnt even help at this point.
Is there a way to have just a simple old corolla like setup where I'll ahve the master cylinder, booster and then then fluid going to the proportioning valve down to the wheels ?
more over , i've been looking over the system today and from what I recon the only thing adding to the system with abs addition is the additional abs actuator. I want to make sure that the part with the bleeding nipple attached to it, behind the passenger side headlight right below the air intake is the proportioning valve, and the part closest to the headlight is the abs actuator.
can someone confirm that for me. better yet could someone perhaps post the diagram here if available for a 93LS400 with traction control.
thnx.
RDLGX
NX - 1st Gen (2015-2021)
18
11-09-15 01:21 PM
eemueller
Suspension and Brakes
05-14-13 08:10 AM
adam8103
11-24-08 09:02 AM
RocketGuy3
08-12-08 09:22 PM
ihiryu
Performance & Maintenance
06-05-08 11:35 AM
Quick Reply: proportioning valve / abs actuator
