Polyurethane Rear Swaybar Bushings for under $20
Old 05-17-04, 11:25 AM
  #31
Lexkost
Lexkost's Avatar
Energy Suspension Part numbers for 2nd gen LS are:
For the 1 1/16" front bar the part number is: ...............9-5162
For the 5/8" rear bar the part number is: ...............9-5153
Old 05-18-04, 10:58 AM
  #32
Lvangundy
Guest
Posts: n/a
The bushings that usually create a squaking noise are in the control arms, not the sway bars.
Old 05-18-04, 11:09 AM
  #33
Lexkost
Lexkost's Avatar
On 2nd gen it is the rubber on the front swaybars.
I will be looking at the 1st gen this weekend that make noise and see.................Thanks for info. Mike
Old 05-18-04, 03:47 PM
  #34
buttons
buttons's Avatar
I need to measure the bar size on the Gen 1.
Are these their generic mounts[as listed at the end of their site] by bar size??
Old 05-27-04, 03:13 PM
  #35
retrodrive
Search Function Inc.
retrodrive's Avatar
Any updated on the 1st gen swaybar sizes, bushings etc?
Old 05-28-04, 07:53 AM
  #36
Rice
Rice's Avatar
Just went on to Energy website and looked up Universal Applications.
The model number for 5/8 diameter is 9.5154 .
Is that the right one or should it still be 9-5153 ?
9-5153 is listed for 9/16" / 14mm diameter.
Old 05-28-04, 10:15 AM
  #37
Lexkost
Lexkost's Avatar
Rice, the 9-5153 is listed for 9/16" / 14mm diameter, this is the one you need for the rear of a 2nd gen. LS.
Old 05-28-04, 10:19 AM
  #38
Lexkost
Lexkost's Avatar
Retro, On the 1st gen the front bar is 1 1/16" and the rear is 3/4 , But I have not installed them yet so hold on until I know that they fit !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 05-28-04, 12:04 PM
  #39
retrodrive
retrodrive's Avatar
what about the sway bar itself. Did you check if 2nd gen is thicker then 1st gen? Are they interchangeable?
Old 05-28-04, 12:11 PM
  #40
persian451
persian451's Avatar
Pete i dont think there is a significant advantage for putting a larger sway bar.. check this out though....
http://performancecenter.com/product...&sortorder=ADA
Old 05-28-04, 06:28 PM
  #41
persian451
persian451's Avatar
Originally posted by xmystikx
does that fit?? if so, I WANT ONE!
it says it does.. you'd be the first to try it out
Old 05-28-04, 08:07 PM
  #42
RA40
Super Moderator
RA40's Avatar
http://performancecenter.com/produc...d&sortorder=ADA
This site shows an application for the UCf20/21 too. However when I check Addco's site, they don't list any Lexus products.
I was getting all hyped up since a rear bar will take that last bit of understeerr out. (hopefully)
Old 05-28-04, 08:23 PM
  #43
persian451
persian451's Avatar
call the company up, maybe its discontinued or something, or maybe its a universal application
Old 05-29-04, 12:35 PM
  #44
RA40
Super Moderator
RA40's Avatar
Addco was unresponsive when I called back in '01 about a sway bar application for the 20/21 Lexus. This Perfomance Center shows rear bars in thier catalog for the 10/11 and 20/21. When the weekend is over, I'll call Addco and inquire.
Old 06-01-04, 08:29 PM
  #45
retrodrive
retrodrive's Avatar
I will wait for this.
http://www.tmengineering.net/suspens...n/make/ls.html
since I already have my Daisen bushings installed in the front I might as well wait and have full Daisen suspension setup. I am pretty confident that their setup would be pretty much flawless.
Here is a quick review on the front bushings: http://www.cureline.net/lex/performa...ion_shocks.htm
Quick Reply: Polyurethane Rear Swaybar Bushings for under $20
