PCV valve....time to replace?
I've noticed a little bit of gunk and moist grime around the pcv valve......is this an indication that it's time to replace it? If not...what does it mean?
Originally posted by Strida
It means the pcv valve is already clog an need of replacement. Cheap and very easy DIY.
Where in Canada are you Strida?
Remove pcv and clean it with WD-40 inside and out ..............If you have a build up around it make sure the grommet is ok on valve cover...................MIKE
Originally posted by TooPhat
I will do this ASAP....and I already found the DIY on Earl!'s website!! so big thanks to him. Great Website...can't wait to see it grow. Already am planning to change my rotor's in the Spring!!
PVC value is easy. $10 part and <10 minute job, simple.
if I clean it with WD40 is there anyway to tell if it's time to be replaced....are they ok to use over again? Or am I better of bitting the bullet and spending the big $10....or 13.68 CND on a new one?
I live in Mississauga, Ontario, just spend $13 and have a brand spanking new pcv and maybe change the pcv hose while your at it.
Yes he could check if the pcv valve is still okay but why take a chance? It might get clog again in a few weeks. I doubt that valve is in good working order. It may even be < $13cdn.
Originally posted by 99lsguy
TooPhat,
Just noticed your car has 230,000 miles.....
What's the history and how's it running......
99lsguy
TooPhat,
99lsguy
Only running complaint is the typical tapping...and idle is a bit rough....but spark plugs are due for a change long ago....so that hopefully will clear it up. I just drove from Nova Scotia to Ontario, over 2000km's, and drove 10 hour days. Made it with no problems. So can't complain!
Originally posted by persian451
i just changed my pcv valve, and I dont think its ever been changed in 180k miles, and i tell you, i think i gained an extra 30 miles/per full tank
PCV Valve #'s 90-94 LS
Some Part # 's here would be very helpful:
I searched specifically for 94's :
Toyota part # 12204-50010
Bosch , B2040-79136 ?? ( not sure on this one)
Beck/Arnley , 0450291
Fram , FV323
Purolator PV 1038
Fram , FV323
Purolator PV 1038
