Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS400
Sign in using an external account
Register Forgot Password?
What could this leak be?
Thread Tools Search this Thread Display Modes
Old 04-20-04, 02:24 AM   #1
psls400
Trader Score: (0)
Question What could this leak be?
Hi Guys
My 91 LS has just reached 276,000km with no probs until this morning! I noticed an oil leak (not sure if motor oil, however very thin in viscosity) in the vicinity of the oil filter/front left wheel arch/suspension areas. I inspected the plumbing around the oil pan etc with no evidence of leak. However, I did notice power steering rack slightly "wet" with traces of oil around alloy wheel and near rack dust boot. Any ideas?
Cheers!
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
psls400 is offline   Reply With Quote
Old 04-21-04, 03:29 AM   #2
SharpLS-96
Trader Score: (0)
SharpLS-96's Avatar
Hard to tell from your description, is the fluid brown or reddish color in nature?
My guesses are:
1-Oil filter might not be screwed on tight enough or could just be old oil from when your mechanic removed your oil filter that dripped.
2-One of your power steering lines might have a slight pin hole in it.
3-Driver's side engine valve cover might be leaking.
4-Could even be your driver's side strut leaking.
Most likely it's one of the above I mentioned.
If you still can't find the origin of the leak try steam cleaning your entire engine bay as well as the undercarriage (remove the plastic protective piece/pan if you have it) and then see if you locate the area once it leaks again.
__________________
In Memory of 9/11/01
http://www.clublexus.com/gallery/dat...of_9-11-01.jpg
"THIS GREAT NATION WILL LEAD THE WORLD AND WE WILL BE SUCCESSFUL!" --GEORGE W. BUSH
"I SAY TO OUR ENEMIES: WE ARE COMING! GOD MAY HAVE MERCY ON YOU, BUT WE WON'T!"--JOHN McCAIN
"THE PROBLEM WITH LIBERALS IS NOT THAT THEY'RE IGNORANT-IT'S THAT THEY KNOW SO MUCH THAT ISN'T SO!" --RONALD WILSON REAGAN -- MAY HE R.I.P.
SharpLS-96 is offline   Reply With Quote
Old 04-21-04, 05:35 AM   #3
psls400
Trader Score: (0)
Thumbs up
Thanks for the suggestions.
I steam cleaned it today. Will see if can locate leak.
Cheers!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
