Taking of Exhaust Heat Sheilds ok?
Old 03-16-04, 03:24 PM
Jasoneo5
Jasoneo5's Avatar
Default Taking of Exhaust Heat Sheilds ok?
Hey Guys,
I have recently taken off my 2 rear exhaust heat sheilds because they were rattling like CRAZY! Is this okay? Is there any type of fire hazard or negative effect to doing this?
Should I put them back on and just put up with the horrible rattling?
Thanks as always,
-Jason
Old 03-16-04, 08:44 PM
RA40
Super Moderator
RA40's Avatar
If it were my car, I'd attempt a fix to eliminate the rattles. A rubber grommet, washers or just plain bending them from whatever may be touching them. On mine, there is like 2" of air space...so you are likely okay without them. Check the underside for any signs of heat damage though.
Old 03-19-04, 06:40 PM
TOPLEXS
TOPLEXS's Avatar
Last thing I would do is remove a heat shield. They are usually designed to prevent fires. Sometimes they are installed beneath the exhaust, to prevent starting a grass fire if you were to park off the pavement.
You could stop the rattling by wiring them on. A coat hanger would not be the best looking, however that seem to be the traditional fix. (Very un Lexus-like).
Old 03-21-04, 07:29 PM
lspower
lspower's Avatar
i took off my middle ones and i think the one above where the silencer was because, well theres no middle mufflers, or silencer
yonexyr
Performance
09-14-15 07:49 AM
SeanGTS
IS F (2008-2014)
01-17-13 06:19 PM
i3urton
11-04-09 05:02 PM
Quick Reply: Taking of Exhaust Heat Sheilds ok?
