97 LS400 Big brake setup on 93 LS400?
Old 02-29-04, 09:23 PM
ATSOU
ATSOU's Avatar
Question 97 LS400 Big brake setup on 93 LS400?
I've got a total lost 97 LS400 at my shop. I'm plannng to take out the front brakes with 4-piston calipers for my 93 LS400. Is this a possible swap? How am I going to do this, install with the whole knuckle?
Old 03-02-04, 12:50 PM
RA40
Super Moderator
RA40's Avatar
That would be my thought...install the knuckle/spindle if it will fit the later A-arms.
Old 03-03-04, 12:16 PM
Lexkost
Lexkost's Avatar
Default Re: 97 LS400 Big brake setup on 93 LS400?
Hey Lonely , Call dealer and find out what parts are the same for 1st to 2nd and start there... .............When working on persian451's car I tried to put some 2nd gen rotors on to see the difference so I have a good idea what has to be done..............And also your wheels may not clear do to offset.......If you want some help PM me ........................MIKE
Old 03-07-04, 11:18 AM
aliga
Former Sponsor
aliga's Avatar
cant you just swap the rotors and calipers?
Old 03-08-04, 01:41 PM
Lexkost
Lexkost's Avatar
NO, more to it than that........
Old 03-08-04, 01:54 PM
aliga
Former Sponsor
aliga's Avatar
im going to try this setup on a sc300 on the weekend
Old 03-08-04, 05:47 PM
persian451
persian451's Avatar
didnt we need to chagne the spindle as well to make the application work?
Old 03-09-04, 12:08 AM
ATSOU
ATSOU's Avatar
I think the spindle swap is easy, I'll just remove the knuckle with rotor & caliper and swap it on........I'm affraid that there are some custom brackets needed to fit this project
Old 03-09-04, 12:29 AM
persian451
persian451's Avatar
well, we can't say it doesnt work unless someone tries it first
Old 03-09-04, 01:05 AM
RA40
Super Moderator
RA40's Avatar
This may be pretty involed as I've thought about it more.
Certainly nothing a plasma cutter and some welding cannot overcome. For the average guy though, this become complex.
Wheel off-set,
hub
Let alone the brackets to accomodate the caliper for the larger disc.
I wonder if the whole A-arm asembly may bolt up...then it is a whole swap so long as it does not throw the front track off.
As persian said, gotta try it.
Old 04-28-04, 08:14 AM
aliga
Former Sponsor
aliga's Avatar
just posting my results, i was able to swap the front ls400 rotors and calipers to the sc.
how many piston do the 95+ ls rear calipers have?
Old 04-28-04, 08:28 AM
persian451
persian451's Avatar
i think 2
Old 04-28-04, 01:51 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
Lightbulb
Hey Eric,
I've got a better idea....do a Supra TT big brake swap instead.
Old 04-28-04, 03:09 PM
aliga
Former Sponsor
aliga's Avatar
great idea, it costs two to three times more.
Old 04-28-04, 03:21 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
Shouldn't be a problem for him.
Quick Reply: 97 LS400 Big brake setup on 93 LS400?
