Strut Tower Brace for UCF20
Old 11-14-03, 10:22 PM
RA40
Super Moderator
RA40's Avatar
Default Strut Tower Brace for UCF20
After seeing Lexkost's STB install, I ordered a Supra turbo version off eBay and it arrived today. Unlike his, my bar was straight and I suspected that this would be a clearance problem. When doing a test fit, I discovered it was exactly that. It will not clear the engine cover.
You need the bar that has the bend. For the straight bar to clear, it would need about a 3/4" thick spacer and that leaves very few threads left to install the strut nuts with. Does the UCF 10/11 have the engine cover clearance problems?
This bar is made in Taiwan. The welds on the risers are clean and symmetrical and the paint is reasonable. The aluminum cross member has coarse grit scratches from before they buffed the finish...not pretty up close but not obviously so. (How many of us sit there looking at welds and the finish?
Oh well.
Old 11-14-03, 11:10 PM
persian451
persian451's Avatar
nope, just got mine today, fits like a charm, except brake cylinder in the way, no problem
Old 11-15-03, 01:32 AM
RA40
Super Moderator
RA40's Avatar
I'll order a bar with the bends in it and see. What I find amusing is the high shipping costs of these things. $15+. I may call a local shop and inquire...I suspect it will be $25 + tax. LOL.
Is your bar straight or does it have the bend?
Old 11-15-03, 08:35 AM
persian451
persian451's Avatar
its straight, no bend..
Old 05-24-04, 10:00 AM
Lexkost
Lexkost's Avatar
Default LS Strut Bar.....must have this to fit ! !
There seems to be a lot of confusion on the Strut Bar for the LS, for the proper fit 2 things are needed:
One the bar must have bend on the ends , turn down to give clearances to the engine.
Two a 1/4" spacer under the strut bar mounts.
Old 05-24-04, 10:01 AM
Lexkost
Lexkost's Avatar
Another view :
Old 05-24-04, 10:08 AM
Lexkost
Lexkost's Avatar
Pic of the spacer note it is the silver piece under the strut tower bracket :
Old 05-24-04, 11:05 AM
Lexkost
Lexkost's Avatar
Originally posted by xmystikx
Lexcost! can i buy the spacers yet??
I will be making some shortly I will PM you when done .
Old 05-24-04, 11:42 AM
SQ-LS
SQ-LS's Avatar
So are you selling spacers and strut bars?
How much you thinking? I might put another one back on my car if it isn't too much.
Old 05-24-04, 01:57 PM
persian451
persian451's Avatar
Strut bars off ebay are from 25-60 depending on what kind.. i got mine for 25 shipped and works well..
Old 05-24-04, 05:41 PM
AusLexus
AusLexus's Avatar
Hi guys,
stupid question, but:
What does a strut bar do?
Regards,
Tim
Old 05-24-04, 09:45 PM
SharpLS-96
SharpLS-96's Avatar
Originally posted by AusLexus
Hi guys,
Regards,
Tim
A front and rear Strut Bar stabilizes the car in order to minimize the effect of body roll around curves/bends/turns etc.
Old 05-25-04, 08:27 AM
Jasoneo5
Jasoneo5's Avatar
Can I buy a spacer from you Lexhost?
Old 05-25-04, 10:09 AM
Lvangundy
Guest
Posts: n/a
Old 05-25-04, 12:08 PM
persian451
persian451's Avatar
Quick Reply: Strut Tower Brace for UCF20
