Tappy Tappy Tap
Old 11-04-03, 06:24 PM
TooPhat
TooPhat's Avatar
Arrow Tappy Tappy Tap...name that noise
My ol Lex has had this tapping noise eversince I bought it which I know is common in the higher milage V8's. I'm 99%sure it's the valves as you can hear them very well towards the back of the engine on both sides. I read once that there is a fluid you can put in your oil which will make the sound decrease for a bit depending on the severity. ANyone know what type of fluid this is?
Along with that there is a much louder ticking under acceleration and sounds to be coming from under the car upon closer inspection. Exhaust manifold gasket perhaps??
Old 11-07-03, 03:59 PM
TooPhat
TooPhat's Avatar
bump
Old 11-09-03, 10:14 AM
Strida
Strida's Avatar
What type of oil do you use?
Old 11-09-03, 12:45 PM
TooPhat
TooPhat's Avatar
5w30...should I try 10w30??
Old 11-10-03, 01:03 PM
Strida
Strida's Avatar
Yes, try using 10w30. I would have suggest 10w40 or 15w50 but since its freaking cold already, use Mobil 1 10w30. Its not the ultimate solution but it will help for now. Caution though since you have a high mileage car you might develope an oil leak. If you do, try mixing it with 10w30 coventional oil and synthetic. But i have been using it for years now and never had any oil leaks from my cars including my 370,000 km 1991 nissan sentra
In my 300zx I had that tapping and ticking sound, so I used Mobil 1 15w50 in the summer and never heard of the sound again.
Old 11-10-03, 04:39 PM
TooPhat
TooPhat's Avatar
merci beaucoup. I will try that asap. I might try just regular 10w30 forst......I had the bad leaky problem with changing to synthetic in a previous car with high milage....but I might give it a shot
Old 11-10-03, 04:55 PM
retrodrive
Search Function Inc.
retrodrive's Avatar
http://www.cureline.net/lex/howtos/i...ing_engine.htm
jboy
Maintenance
16
05-05-05 05:42 PM
oayodeji
09-08-04 07:16 PM
toy4two
RX - 1st Gen (1999-2003)
09-05-04 10:03 AM
ES3
03-03-04 10:11 PM
ruki400
Maintenance
11-22-02 04:14 PM
Quick Reply: Tappy Tappy Tap
