Lung nuts on rim?
Old 11-03-03, 09:30 PM
telegix
telegix's Avatar
Default Lung nuts on rim?
Could someone tell me how many lung nuts on the rim of a LS430 there is.. I'd like to put some steel rims and tires (winter of course) on which I am using from a 1997 Cadillac STS.. I'm wondering if it has the same amount of holes.. Thanks..
Old 11-04-03, 09:12 AM
LS4fun
LS4fun's Avatar
There are 5. But be careful, even though the wheels may have 5 bolts...the bolt pattern may not be the same and the rims may not fit!
Do a comparison on bolt pattern first to ensure a proper fit!
Old 11-04-03, 09:16 AM
telegix
telegix's Avatar
I have no LS430 yet, but a 1997 cadi sts thats going to be replaced in the spring.. I'll have to ask a tire place who'll know if it will fit or not..
Old 11-04-03, 10:11 AM
mtsao
mtsao's Avatar
Check out www.tirerack.com and use their site to search for rims that are compatible with the 2 vehicles you are interested in. I think the rims that the system shows you as being compatible will have their bolt pattern specs and then you can just compare. Also here's their explanation of bolt/lug patterns:
http://www.tirerack.com/wheels/tech/boltpatt.htm
Hope this helps,
Mike
rjsix
Wheels, Tires & Brakes Forum
03-15-09 12:43 PM
Warrenbic
Suspension and Brakes
05-23-08 01:41 PM
4age-turbo
16
02-26-08 01:39 PM
1stgenGSb
GS - 1st Gen (1993-1997)
06-23-07 08:34 AM
FlintGS06
06-29-05 09:29 PM
Quick Reply: Lung nuts on rim?
