Error PCD and VSC
Old 12-05-16, 08:53 PM
DeBaloon
DeBaloon's Avatar
Default Lexus LS460 , Error PCD and VSC and ABS si
HI
First time posting here. I recently got new battery installed in my Lexus LS460.
Car was running fine until this morning.
all of sudden display showed the error PCS and VSC and ABS Sign. I turn off the engin. Turned ON again,errors were there and car was running very slow.
Temperature dropped this morning after snow fall. Could this change in weather created any problem.
Any idea what might have went wrong.
Please advice.
Old 12-05-16, 11:18 PM
DeBaloon
DeBaloon's Avatar
Any help please,
Old 12-06-16, 05:12 AM
greg3852
greg3852's Avatar
First thing I would check is the connections. Make sure they are very tight and the posts are clean. If they are, try to find a place to test the battery and make sure it is good. I know its new, but you never know.
Old 12-06-16, 06:19 AM
jmcraney
jmcraney's Avatar
Originally Posted by DeBaloon
HI
Please advice.
Those warning lights are probably the results of the manner in which your new battery was installed - it was probably installed while the IGNITION was ON. By that I don't mean that the engine was running at the time of installation but the IGNITION was probably ON. It is very common for the ignition to be left on when batteries fail or become fully discharged because of events related to trying to start the car. I can try to explain that again if anyone is interested, but for you, you are probably most interested in how to move on.
So, turn you car's IGNITION OFF. Disconnect the battery by removing the battery-cable from the NEGATIVE terminal of the battery for a few minutes. Reconnect the battery. Start your car normally and allow the electronics to initialize - takes about a minute. If the warning lights are still on after that you will have to get them reset through the car's OBDII port.
Old 12-06-16, 09:45 AM
DeBaloon
DeBaloon's Avatar
I have removed the battery again and stalled after few hours. After system reset again, there is no error light. I am parked inside the garage. I suspect when will drive out on the which still have some snow on it, error will show again. Will update.
Old 12-06-16, 11:13 AM
DeBaloon
DeBaloon's Avatar
HI
Please advice.
i went to a workshop and his computer figured out
P1365
B1206
ertors, he reset them and errors disappeared.
i drove out and errors showed again. Still at workshop
Old 12-06-16, 11:25 AM
GR6RR
GR6RR's Avatar
P1365
https://www.clublexus.com/forums/ls-...and-p1365.html
good luck
Old 12-06-16, 01:07 PM
jmcraney
jmcraney's Avatar
Some of the lights related to Vehicle Stability Control are latched when those systems sense instability and do not reset until the ignition is cycled. Driving on ice or snow or wet roads may invoke some of these warning.
gsssss
01-23-23 09:57 AM
don460
11-24-16 08:06 PM
dmrinehart
05-31-14 07:33 AM
GS300Dude
08-17-09 11:10 PM
UDel
04-06-09 02:17 PM
Quick Reply: Error PCD and VSC
