Routing cable through glove box?
trying to install vline unit. I don't see how to route to glove box. The cabin air filter hole in the back is too far back to route into it and the rest is carpeted with no holes, help!
If you take out the glove box, you can pop open an access door on the bottom left corner. Panel can only can be popped from the left/back side by lifting the tabs. Glove box is easily removed. Three screws behind the wood trim and three screws below the glove box.
Cable through Glove Box
Can you please share a picture of where the access is in the glove box.
Also any input how I can go about getting the Grom unit in the Glove box to connect to factory head unit
Thank you for your help
GM430
GM430
