Extended Warranty: Brake Actuator 2007+ LS 460 1st Phase Expires Dec 31 2017
DO NOT PAY FOR A NEW BRAKE ACTUATOR.
I suggest doing this before Dec 31 2016 to be sure... Note the Primary Coverage vs. Secondary Coverage conditions.
The New part number should be verified per Warranty Policy Bulletin 16-01 (released April of 2016).
See the Warranty Enhancement Program - ZLG which says in part:
"This Warranty Enhancement Program provides enhanced coverage to the vehicle’s “New Vehicle Limited Warranty” as it applies to the Brake Actuator Assembly. The specific condition covered by this program are repairs related to an internal malfunction of the Brake Actuator Assembly. If the condition is verified, the vehicle will be repaired with a new Brake Actuator Assembly at no charge under the terms of this Warranty Enhancement Program.
* The Primary Coverage offers warranty enhancement until December 31, 2017, regardless of mileage.
* After the Primary Coverage ends, the Secondary Coverage is applicable for 10 years from the date of first use, or 150,000 miles, whichever occurs first.
This coverage is for warranty work performed at an authorized Toyota dealer only. It is subject to the same terms and conditions set forth in the New Vehicle Limited Warranty Section of the Owner’s Warranty Information booklet. For example, damage from abuse, an accident, theft and/or vandalism is not covered by the New Vehicle Limited Warranty or this warranty enhancement."
I believe the new part number is # 44050-50150 which replaces part # 44050-50130. A 2009 Service Bulletin also mentions issues with the Brake Actuators in the LS 460 and refers to an "improved part", clearly demonstrating Lexus was aware of the faulty part... (L-SB-0178-09).
**The New part number should be verified per Warranty Policy Bulletin 16-01 (released April of 2016).
Eyerly
05-21-18 04:39 PM
