Dead Pedal Mod
Old 09-05-16, 02:15 PM
comotiger
comotiger's Avatar
Default Dead Pedal Mod
I finally assembled and installed the dead pedal for my 2014 LS today. As discussed on another thread (https://www.clublexus.com/forums/ls-...rotection.html), I decided to attempt this job in order to have a nicely coordinated set of pedals after swapping in the 2016 GS-F sport brake and gas pedals for the plain old black LS pedals. Please refer other thread for details of the F-sport pedals.
1) I designed a aluminum plate that was milled on the back side to attach Velcro, and on the front side to inlay black plastic strips. The piece was fabricated by a local university workshop using CNC machines.
Front side
Back side
2) My son (9th grade) designed the plastic inserts to be fabricated on a 3D printer (PrintrBot). After some trial and error, he was able to generate tight-fitting inserts that were glued (inlaid) using JB Weld epoxy.
3) I tested two velcro (industrial and auto, and found the latter generated a stronger bond). Velcro "fuzz" strips were attached to the back side of the plate and the velcro "hook" strips were attached to the dead pedal rubber patch on the carpet.
4) The dead pedal was carefully positioned and attached. Job done!! The plate is firmly stuck to the carpet with no give. I expect it to stay put thru years of "abuse".
Total cost: Fabricated Aluminum plate: $200 (for the shop to convert my line drawings into a CAD model for the CNC machines, buy the Al plate and make the part)
3D printed pieces : $5 (but my son spent about 10 hours designing and printing several prototypes; we use the printrbot for other stuff too)
Velcro and JB Weld : $15
My time (design, test, and help my son) ~20 hours
I am happy to send the design files (aluminum plate, plastic inserts) to anyone interested in making this part.
The pedals really stand out when I open the door, just as I hoped! Needless to say, I am thrilled with the results . Comments welcome.
Old 09-05-16, 02:19 PM
Littleguy
Littleguy's Avatar
These came out looking much more cleanly done than I expected. Sincere props for the OEM like appearance.
Old 09-05-16, 03:00 PM
Rhambler
Rhambler's Avatar
Wow that's nice. Best looking fabrication I've seen yet for our dead pedal
Old 09-05-16, 03:14 PM
Cubbylex
Cubbylex's Avatar
Default Very nice.
Wow, that looks so nice. Professional looking and really does stand out. Congrats to you and your son and the school team.
Old 09-05-16, 03:27 PM
comotiger
comotiger's Avatar
Thanks all, appreciate the kind words. The OEM GSf sport dead pedal is a bit wider at the bottom and tapers to the top. I initially wanted to replicate the inlaid plastic shapes to match those on the gas pedal, but the milling of those shapes on the metal plate would have been quite expensive. So I went with a simpler (and cheaper) design, and it worked out.
The aluminum plate was fabricated by my local university workshop. The plastic parts were 3D printed at home. The rest of the work was done at my dining table
Old 09-05-16, 04:30 PM
droclex
droclex's Avatar
Love it! Looks damn good and you can always look at it with pride knowing that you and your son were the creators. If you make another one, I'll be among the first in line to ante up!
Old 09-05-16, 05:56 PM
Received 2,519 Likes on 1,817 Posts
Awesome! That really looks great,
Old 09-05-16, 07:47 PM
comotiger
comotiger's Avatar
Thanks, guys!
The hard part (design) is done. If you can find a local shop to fabricate the plate (there are also online fabricators: http://www.emachineshop.com), and 3D print the inserts in your public library (or if applicable, your kid's school), you are all set.
Old 04-19-18, 02:52 PM
bigsherv
bigsherv's Avatar
Buddy if you have access to machinery like this why have you not worked on illuminated door sills that are not 1200 bucks.
You would be rich!!!
You would be a hero!!!
You would be a rich hero!!!
comotiger (04-19-18)
Old 04-19-18, 10:17 PM
comotiger
comotiger's Avatar
Those JDM illuminated door sills are really nice. I have been sorely tempted to get them. Maybe in a few years, as I will keep this car for a long time.
Old 04-20-18, 01:09 AM
k311in
k311in's Avatar
Nice!!!!!!!!!
jhs82
NX - 1st Gen (2015-2021)
03-05-21 07:08 AM
peasodos
12-16-18 04:38 AM
LGJeff
04-19-18 10:21 AM
02-28-17 10:28 AM
tucker21
08-08-12 09:32 AM
Quick Reply: Dead Pedal Mod
