Change in Backup Camera Angle
Old 03-11-16, 12:23 PM
Gbp
Gbp's Avatar
Question Change in Backup Camera Angle
I just noticed today that my backup camera now shows part of the rear bumper and perhaps some of the chrome. There's also a strange, small, somewhat circular thing in the upper right corner of the screen. With my Matador Red exterior, I'm sure I would have noticed it before today on the backup camera.
Has anyone else had this issue? Thanks for any insight! I've attached a picture...
Old 03-11-16, 01:53 PM
Rhambler
Rhambler's Avatar
Your camera may have simply moved. While I'm not exactly sure how the cameras are attached to our cars as I haven't looked very closely, the most plausible explanation is that it just moved.
You try gently moving it? If it came loose, see how it is attached. If it's permanently fixed, it may have just loosened, either the housing or the camera within the housing. I'm sure there are brute-force fixes by just manually manipulating it back into place (with the assistance of someone else viewing the camera while you gently try and nudge it).
Since it's one of those wide angle fisheye type lenses, it wouldn't take much to throw the image off so it could be a matter of millimeters. Now the trick, assuming you can put it back, is why it moved to begin with and how you can prevent from moving again.
Lol, I'm just speculating, but seems totally plausible to me.
Old 03-11-16, 08:56 PM
R Z
R Z's Avatar
It's definitely moved. How it moved is a good question. Hopefully you can adjust the camera and out it back. Curious to see how this unfolds.
Old 03-11-16, 09:22 PM
Scrutator
Scrutator's Avatar
Take a look at this thread: https://www.clublexus.com/forums/ls-...test-mode.html
It has links to a service menu where you can adjust the lens. Don't know if it'll work with the LS however.
Old 03-12-16, 02:55 PM
Dr. Jekyll
Dr. Jekyll's Avatar
I've also heard about this in another thread too. If you can't access the service menu at least you know there's a solution at the dealer.
Old 03-12-16, 03:58 PM
Gbp
Gbp's Avatar
The piece that holds the fisheye lens seems fixed in place.
Thanks for confirming that the view isn't normal!
Thanks for the links! I've read them. There's even a video reference to the menu that is supposed to work on the 2010-2012 LS460 models. I'll see if that works. It might not answer the question of why the viewing angle changed, though, and if there's some underlying problem that caused the change.
I had read the thread, thanks. I hope that Stereorob provides some details directly or that perhaps another CL member discovers those details -- independently, of course.
Old 03-13-16, 10:13 AM
roadfrog
roadfrog's Avatar
Your camera angle looks the same as mine. I actually like how it is, since I can see how close something is to my bumper.
Old 03-13-16, 11:20 AM
Received 2,519 Likes on 1,817 Posts
I also can see the bumper in mine the same way. Mine is a little more centered but its a refresh model and the camera was probably moved.
The circular thing in the corner looks like a water droplet to me.
Old 03-13-16, 07:53 PM
Gbp
Gbp's Avatar
I might wait a bit to see how I like it and whether the camera angle remains steady or changes again.
Good eye! I think it was a water droplet.
In other news, with the help of some other threads, I accessed the service and diagnostic menus for my car. Unfortunately, the camera option was grayed-out, and I wasn't able to figure out how to activate it. I'll start a separate thread, in case it would help anyone with 2010 - 2012 MY's. This might just work on Generation 6 navigation, but that's a guess.
Thanks for everyone's input!
phildogbph
GX - 1st Gen (2004-2009)
07-06-20 09:17 AM
MPetrieSLC
CT 200h Model (2011-2017)
09-12-18 03:46 PM
GSFRX350
RX - 4th Gen (2016-2022)
02-12-18 09:30 AM
RookieLEX
ES - 5th Gen (2007-2012)
06-29-16 02:43 PM
yxl8100
06-28-13 11:40 PM
Quick Reply: Change in Backup Camera Angle
